Getting engine back in service.
1 Attachment(s)
I have an OS 46ax which I havent used in almost 2 years. Last I used it, it wa relatively new, about 6 months old. In preparation for one of my winter builds, I was looking through the exhaust port and noticed some grainy particles sitting on the piston head. So I decided to take the engine apart just to cean it all up before I ran it again. Well this is what I found - see pics. I dont have engine rebuild experience other than basic reassembly, so dont really know if its anything to worry about. Seems like very light corrosion on the back plate, crankshaft and rear bearing. How can I correct this? Could I just sand down with very fine sand paper or dremmel, would I need to replace? Any help would be appreciated. Im assuming the rear bearing will need to be replaced.
RE: Getting engine back in service.
ORIGINAL: ro347 I have an OS 46ax which I havent used in almost 2 years. Last I used it, it wa relatively new, about 6 months old. In preparation for one of my winter builds, I was looking through the exhaust port and noticed some grainy particles sitting on the piston head. So I decided to take the engine apart just to cean it all up before I ran it again. Well this is what I found - see pics. I dont have engine rebuild experience so dont really know if its anything to worry about. Seems like very light corrosion on the back plate, crankshaft and rear bearing. How can I correct this? Could I just sand down with very fine sand paper or dremmel, would I need to replace? Any help would be appreciated. Im assuming the rear bearing will need to be replaced. __________________________________________________ ______ PRECISION AEROBATICS BADBOY V2 O.S. 46AX STINGER 12-4 WOOD PROP JR XP6102 COMPUTER RADIO |
[quote]ORIGINAL: ro347 I have an OS 46ax which I havent used in almost 2 years. Last I used it, it wa relatively new, about 6 months old. In preparation for one of my winter builds, I was looking through the exhaust port and noticed some grainy particles sitting on the piston head. So I decided to take the engine apart just to cean it all up before I ran it again. Well this is what I found - see pics. I dont have engine rebuild experience so dont really know if its anything to worry about. Seems like very light corrosion on the back plate, crankshaft and rear bearing. How can I correct this? Could I just sand down with very fine sand paper or dremmel, would I need to replace? Any help would be appreciated. Im assuming the rear bearing will need to be replaced. [/quote P.S. HOBBICO after-run oil sell's for @ $2.50 a bottle plus shipping.....hobbico is only one of many companies that make it......i usually buy 4 at a time and make it an even $10.00 and to take advantage of combined shipping charges....i get mine from tower hobbies.....just a thought.....KOOLKRABBER47..... |
use an sos pad wet to clean up the backplate and crank and replace the bearings.about $15 shipped for stainless
http://www.rc-bearings.com/catalog/p...roducts_id=715 |
The bearings are shot. the regular parts can be saved by removing the rust like whatiworks4 says. to replace the bearings put the new bearings in the freezer to get real cold and then heat up the engine block with the old bearings in it. the hot engine should allow the old bearings to fall out when you strike the engine on a flat wood surface. do not force the new bearings in with anything metal use big wooden dowels to protect the bearings. keep engine warm when putting in cold bearings
Thank you all!!! Im just glad it can be saved. It will be going into my first profile.
Hmmm....SOS pad, isnt that a bit aggressive? I wonder if dremel makes a steel wool disk, so I can get into corners and get a clean result. Just ordered the bearings, $13.29 shipped. Big difference from the Oem cost, and these are stainless steel. |
There isn't any real way to tell if you have a bearing problem or not from a photo, the color or even a little rust may have had no effect on them at all. Living in an area of the country that is humid you will often have a bit of a rust problem. Like Kool stated, I would at least run my engines empty at the end of the day. I'm not a big fan of after run oil but it doesn't hurt to give the engine a little shot at the end of the day. I would just clean your engine and put it back together and give it a try. Just oil up the bearings and give them a twirl then flush them with alcohol and oil them up again. If they are bad you can feel them grinding. Don't get too freaked over a little rust, it isn't the end of the world, clean it up and give it a try.;)
Thanks Gray!
Paraphrasing from a very reliable source ...
Bearing removal. Rear: heat the crankcase around the rear main bearing 'til hot (use a glove or towel). With a solid downward motion, hit the rear of the block against a pad of paper or a piece of leather. The bearing will jar loose. Front: heat the crankcase around the bearing, tap the bearing out with a wood dowel and a plastic hammer. Bearing installation. Freeze the bearings. Rc-bearings ship theirs in nice small ziplock bags - just toss it in the freezer. Rear: Slide the rear bearing down over the crankshaft 'til it bottoms out. If it won't slide down because the bearing is cold and the crank is warm - freeze the crank too. Heat the case around the bearing seat. Insert the bearing-n-crank with a wood dowel inserted into the back of the crank. Then seat the bearing into the case and use a sharp blow of a plastic hammer to seat if necessary. Front: heat the case around the front bearing seat. Have a solid surface with a hole drilled to accept the front of the crank. Place bearing over the crank and position the assembly so that the crank will go into the hole, then use the wood dowel inserted into the back of the crank and a plastic hammer drive the front bearing into its seat. A reassembly note: the connecting rod big end hole is flat on one side and beveled on the other. When you reassemble, the bevel is installed towards the back plate. Another approach: slide the main bearing over the crank & seat it. freeze both bearings & crank. heat the case in the oven at 300 degrees. insert the crank into the warm case - the bearing may seat beautifully - make sure that you keep the bearing seated while the hot & cold items equalize. slide the front (frozen) bearing over the crank and it may seat itself. |
Thanks for the support guys. One more question: Once I remove the rust, what should I be coating the engine parts with during the rebuild stage?
I use air tool oil as my assembly lube applied with a q-tip. After run oil would work too.
ORIGINAL: ro347 Thanks for the support guys. One more question: Once I remove the rust, what should I be coating the engine parts with during the rebuild stage? ro347......i told you everybody would chime in here after they were done "power napping" from eating all that good turkey stuff......by the way, a q-tip work's good, so does an epoxy brush, i use the epoxy method, the bristle's get in to those crevises pretty good.....when i reassemble my motor, i sometimes use 3-in-one oil, because my other hobby is boat upholstery, i alway's tend to have some 3-in-one laying around, i use the 3-in-one to lube my commercial sewing machine,too.....good luck with the motor.....KOOLKRABBER47...... |
ORIGINAL: koolkrabber47 ORIGINAL: ro347 Thanks for the support guys. One more question: Once I remove the rust, what should I be coating the engine parts with during the rebuild stage? ro347......i told you everybody would chime in here after they were done ''power napping'' from eating all that good turkey stuff......by the way, a q-tip work's good, so does an epoxy brush, i use the epoxy method, the bristle's get in to those crevises pretty good.....when i reassemble my motor, i sometimes use 3-in-one oil, because my other hobby is boat upholstery, i alway's tend to have some 3-in-one laying around, i use the 3-in-one to lube my commercial sewing machine,too.....good luck with the motor.....KOOLKRABBER47...... By the way....how do you like the power of your 46AX on your PA Bad boy with the 12x4? Im basically doing the same setup on an OMP ProYak. |
ORIGINAL: ro347 Thank you all!!! Im just glad it can be saved. It will be going into my first profile. Hmmm....SOS pad, isnt that a bit aggressive? I wonder if dremel makes a steel wool disk, so I can get into corners and get a clean result. Just ordered the bearings, $13.29 shipped. Big difference from the Oem cost, and these are stainless steel. i think the dremel would be too "agressive, especially if you leave it on one area too long.....kinda like sanding a car or a boat for painting, if you don't absolutely know what your doing, you could accidentally leave it in one spot for too long and gouge the paint in the process.....in the case of this motor, if you use a dremel and leave it in one spot for too long and pit the mating surfaces, you won't have the factory-fit and tolerance......you might end up with a loose, sloppy motor or leave a gap/loose-fit and end up leaking oil.....why chance it???....go with the s.o.s. pad's, keep them wet and let the soap do the work, if you run them dry, that's when the begin to scratch the metal......i think you made a wise decision going with the new bearings, why chance locking up the motor in mid-air for the meager price of the new bearings, in this case just $13.00......i don't know how long you been flying????.....for a seasoned pilot like myself, a dead stick is just a walk in the park, i could thermal around the sky forever.....for a newer pilot with average skill's and only one plane to his name, it would not be worth stuffing it into the ground over the price of a set of bearings???.....also keep in mind, from a safety stand-point, it would not be wise or sportsman like to put a plane in the air unless you are 100% certain it is airworthy......i know i alway's check my planes at home the day before i fly and at the field before i fly.....flying is cooool, accidents are not......KOOLKRABBER47...... ________________________________________________ PRECISION AEROBATICS BADBOY V2 O.S. 46AX WITH STINGER 12x4 WOOD PROP JR XP6102 COMPUTER RADIO |
Hey Kool - I soloed in 9 flights, 5 of which were dead sticks. Then there was the Evo 52 - 33 flights 23 dead sticks - needed a new carb. Yup, a walk in the park [:'(]
Ive been flying for 3 years now. I never place a plane in the air unless im very confident that its well tuned and ready to fly.
Thanks for the tips. |
ORIGINAL: ro347 ORIGINAL: koolkrabber47 ORIGINAL: ro347 Thanks for the support guys. One more question: Once I remove the rust, what should I be coating the engine parts with during the rebuild stage? ro347......i told you everybody would chime in here after they were done ''power napping'' from eating all that good turkey stuff......by the way, a q-tip work's good, so does an epoxy brush, i use the epoxy method, the bristle's get in to those crevises pretty good.....when i reassemble my motor, i sometimes use 3-in-one oil, because my other hobby is boat upholstery, i alway's tend to have some 3-in-one laying around, i use the 3-in-one to lube my commercial sewing machine,too.....good luck with the motor.....KOOLKRABBER47...... By the way....how do you like the power of your 46AX on your PA Bad boy with the 12x4? Im basically doing the same setup on an OMP ProYak. I LOVE IT???.... oh!, did i say that loud enough????.....low pitch prop is the trick and keep it very,very light.....something in the 12x4 size with minimum flex will work best.....these profile planes were not meant for speed, i've got other planes for that......the design factor behind the profile fuselage was to narrow the fusealage and allow as much air as possible to flow over the control surfaces(ailerons,elevator,rudder)......low pitch prop allows the motor to maintain high RPM's at all times and thus huge amounts of constant air-flow over the control surfaces at very low speeds, without too much forward thrust.....that's how these 3D'er's came about.....i like that i can bring this thing "low" and "inside", right down on the runway.....boy, you talk about "drawing a crowd"......i bring this thing right down on the runway and keep it moving the whole time, head over tail, tail over head and yet it stay's in a 10-20 foot envelope the whole time.....ro347, "ARE YOU DROOLIN' YET", HA! HA! HA!.....get that thing built brother, p.m. me brother, if i can be of any assistance.....KOOLKRABBER47..... |
Hey Kool - just looked up Ilwaco, WA - wow, that's gotta be a slice of God's country. Love your contributions!
Got it all cleaned up...now a little heat to dry up any moisture. Question: Only 1 part left if I can figure this out - How do I get the connecting rod pin out of the cylinder. I pulled out the little clips in the cylinder, but cant get the pin to slide out. Tried tapping it, nothin!!!! Any ideas?
ORIGINAL: ro347 Got it all cleaned up...now a little heat to dry up any moisture. Question: Only 1 part left if I can figure this out - How do I get the connecting rod pin out of the cylinder. I pulled out the little clips in the cylinder, but cant get the pin to slide out. Tried tapping it, nothin!!!! Any ideas? |
1 Attachment(s)
ORIGINAL: SeamusG Hey Kool - just looked up Ilwaco, WA - wow, that's gotta be a slice of God's country. Love your contributions! |
ORIGINAL: koolkrabber47 ORIGINAL: SeamusG Hey Kool - just looked up Ilwaco, WA - wow, that's gotta be a slice of God's country. Love your contributions! |
15 min from NYC lucky...lol not when you live out this way ro347! Born and raised back east, I'll only visit now! :) West side is where its at!:D
I've got an Enya .80 like that, wonder if I should give it a go?[&:] Yer kewl s**t Kool!:) I hope to be that hip when I get there!http://www.rcuniverse.com/forum/js/f...ey/msn/lol.gif |
ORIGINAL: RevyMaxx 15 min from NYC lucky...lol not when you live out this way ro347! Born and raised back east, I'll only visit now! :) West side is where its at!:D I've got an Enya .80 like that, wonder if I should give it a go?[&:] Yer kewl s**t Kool!:) I hope to be that hip when I get there![img][/img] As far as the Enya - give it a shot. I completed mine in a matter of a few hours. It was very simple thanks to the help of those that gave advice here ( Thank you). I'll just have to wait for the bearings to come in, but have no doubt the engine will run just fine. |
Stopping off in the Rockies ain't so bad either - just reduced HP ...
1 Attachment(s)
ORIGINAL: ro347 ORIGINAL: ro347 Got it all cleaned up...now a little heat to dry up any moisture. Question: Only 1 part left if I can figure this out - How do I get the connecting rod pin out of the cylinder. I pulled out the little clips in the cylinder, but cant get the pin to slide out. Tried tapping it, nothin!!!! Any ideas? |
ORIGINAL: koolkrabber47 ORIGINAL: ro347 ORIGINAL: ro347 Got it all cleaned up...now a little heat to dry up any moisture. Question: Only 1 part left if I can figure this out - How do I get the connecting rod pin out of the cylinder. I pulled out the little clips in the cylinder, but cant get the pin to slide out. Tried tapping it, nothin!!!! Any ideas? How is the pull out from a hover with the 46AX on the Bad Boy,,,,strong or does it struggle? |
I was from Tacoma, so far no one has mentioned how long it takes to develope the webs between your toes!! I know it takes a couple of years before they go away. About twice as long then it took the moss to fall off.:D
[quote]ORIGINAL: ro347 ORIGINAL: koolkrabber47 ORIGINAL: ro347 ORIGINAL: ro347 Got it all cleaned up...now a little heat to dry up any moisture. Question: Only 1 part left if I can figure this out - How do I get the connecting rod pin out of the cylinder. I pulled out the little clips in the cylinder, but cant get the pin to slide out. Tried tapping it, nothin!!!! Any ideas? How is the pull out from a hover with the 46AX on the Bad Boy,,,,strong or does it struggle? [/quote to steal a line from "jackie gleason" i think it was.......to the moon alice, to the moon!!!......did i get that right???....i'm pretty freakin' old(48), or my son's keep tellin' me, but i gotta admit, i never watched any of his movies.....13 oz. motor with @1.75 hp add the stealthy 12x4 zinger prop= very happy pilot.....if you use a high pitch prop you will have less torque and more forward thrust, not what you want for a true 3Der.....with the low pitch prop your able to maintain high RPM's which equals lot's of low end power(torque) with minimum thrust for those 3D maneuvers, including but not limited to hovering......it's kinda like motocross bikes....they gear them real low and alway's keep them wound up so they can launch out of corners and straightaway's......with the large diameter, low pitch prop, you can still acheive plenty of speed, being that the O.S. 46ax is capable of @ 17,000 RPM's easily......but with most 3Der's your not looking for crazy speed, if your like me you've got other planes for that???....i don't know about your plane but in the build manual that came with my badboy, it clearly states, about 3-4 times to avoid flying the badboy at full wide-open throttle.....some of these 3Der's have thick airfoils on the main wing and if flown wide open they catch too much wind which in turn would create too much flutter......flutter is when the plane begins to shake eratically and the plane disintigrates like confetti......WOW! kinda neet to watch but, a bit dangerous depending on the direction the plane is traveling when it comes apart???....i would hate to see it hit somebody......man, when those things flutter, it's like "pow", instant confetti all over the runway.....be safe, stick with the 12x4 prop and experiment from there, depending on your particular style of flying you can alway's change up later???.....the RPM's you are able to maintain with the 12x4 allow's you to land real slow and hover effortlessly without worrying about loading up the carb, remember the dirt bikes?, same principal idea.....in a nice, tight hover, the high RPM's allow you to pull out of a hover effortlessly, straight up to the moon(remember jackie gleason)....ha! ha!......make sure you balance your plane very carefully, horizontally(front to back) and laterally(side to side), this is very important when hovering so your plane won't keep trying to lay on it's side and fall out of an otherwise perfect hover.....if your plane is properly balanced, it should hold a tight hover with minimul stick input and free-up your attention, so you can concentrate on other things.....there are several threads here on RCU that deal with properly balancing an airplane.....try shifting your batteries and reciever,etc. around before you glue them in place, to acheive the proper balance, rather than add a ton of weight.....keep your plane light.....a lighter plane can run a smaller motor and still maintain the same, if not better, power-to-weight ratio.....the lighter motor and plane will also consume less fuel/nitro and at $20-$30 a gallon, we could all get used to that......ro347, enjoy the yak.....ask alotta questions....get it right the first time......i hope this helped......if not, somebody please chime in here and help add to this young man's success.....KOOLKRABBER47....... |
it will pull out of the hover but a 55 ax will make it jump out of the hover. if you are tail sliding it will take a second or so to stop the slide before it pulls out. its the difference between ok and outstanding
ORIGINAL: rlipsett it will pull out of the hover but a 55 ax will make it jump out of the hover. if you are tail sliding it will take a second or so to stop the slide before it pulls out. its the difference between ok and outstanding ARRRRRRR!!......as far as jumping out of a hover, you got me there......i like to keep my planes light and shoot for a nice, long glide ratio....although the 55ax is only a few ounces heavier than the 46ax, oz.'s will still lead to lbs. eventually......i don't have any 55's but, i do have three 46's, i am very happy with the power.....i have a number of electric's as well.....i hear a lot of people say the cheapy electric motor's are as good as the name brand....i'd have to say that's probably wishful thinking???.....i stick with the HI-MAX,E-FLITE,HACKER LINES, just like the o.s.ax line, the quality and power are phenominal......same goes for the castle creations line of esc's, outstanding quality and lot's of programming features built-in and accessable with a USB/computer hook-up.....rlipsett, talk is cheap.....post us fan's some pictures of just what "outstanding" looks like???.....Ha! Ha! Ha!......KOOLKRABBER47.......... |
| All times are GMT -8. The time now is 06:55 AM. |
