RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   CA hinges on a P-51 (https://www.rcuniverse.com/forum/beginners-85/9290808-ca-hinges-p-51-a.html)
chocorrol 11-29-2009 10:35 PM
CA hinges on a P-51
<span lang="EN-US" style="font-size: 9pt; font-family: Arial; mso-ansi-language: EN-US">wel, Ifinally got my Top Flite P 51 and started the construction fun... Itook a look into Minn's article about CAhinges and Ifollowed all the instructions but one of the ailerons didn't pass the pull test and came off, the funny thing is that Imade the same steps on both ailerons and the other one seems to be ok since I tried to pull it very hard and nothing happened... now, my question would be how can Ifix this problem? The hinges slots are pretty big and Ithink Ican insert another hinge just in the same slot but just a little aside from the place Iglued the first one, could this work? I'm not good at making slots so Iwould like to avoid making another slot for every hinge.. the other thing is that in the good aileron there is a gap of about 2 1/2 mm between the aileron and the wing, is this gap to much? chould Iconsider cutting this other aileron and put robart hinges on both of them?
FYIIused the same CA glue and the same hinges sheet for both ailerons so Idon't think the problem could be the glue or the hinges quality.
Any suggestions would be appreciated.
Thanks!<o:p></o:p></span></p>
dignlivn 11-29-2009 10:40 PM
RE: CA hinges on a P-51
Have you thought about pinning the
hinge ?
Bob
MinnFlyer 11-29-2009 10:40 PM
I would remove them all and use Robarts. You COULD only replace the one side, but as long as you're at it, you might as well do both.
chocorrol 11-29-2009 10:44 PM
<p style="MARGIN: 0cm 0cm 0pt" class="MsoNormal"><span style="FONT-SIZE: 9pt; FONT-FAMILY: Arial; mso-ansi-language: EN-US" lang="EN-US">I'm assuming so far that using the same slots won't be a good idea. Am I correct?
</p></span></p>
MinnFlyer 11-29-2009 11:17 PM
Correct. The pores inthe wood are sealed now and thin CA won't take very well.
chocorrol 11-29-2009 11:29 PM
and what about using nylon hinges glued with epoxy?
MinnFlyer 11-30-2009 08:20 AM
You can do that.
Mikecam 12-01-2009 09:04 AM
I switched all my hinges to robarts on my TF P51 when I broke an elevator hinge. Buy the robart jig tool, makes it very easy and some pacer hinge glue and you will be very happy with the result. Melt some Vaseline and dip the hinge pin before gluing.
MinnFlyer 12-01-2009 09:14 AM
I just smear a little Vaseline right on the hinge pin with a toothpick and then heat it with a lighter so it melts right in
chocorrol 12-04-2009 08:26 PM
and what hinges size chould be fine for this plane? I'll totally go for robarts, Imade several tests with the provided CAhinges and the same results every time... maybe I'm doing something wrong...</p>
MinnFlyer 12-04-2009 08:49 PM
Get the 3/16" robarts
