Larger wheels on the Superstar
Thinking about replacing the 2.5" foam wheels with 3" rubber wheels on my Superstar.
Would there be a problem with aerodynamics or weight? Thanks! |
I have never used wheels of the recomended size. I always go 1/2" to 1" larger depending on the model. My Sig SE has 3.5" wheels. Think the plans called for 2.75" or something like that.
I like the extra prop clearance and the fact it rolls over some of the smaller boulders and mountians in our grass area. You will not notice any other than myabe a slight bit of change in the cg depending on how big and heavy they are. |
Go with 3" foam, no problem.
I would also look for foam wheels or lightweight rubber. The heavy rubber wheels will add weight that you don't need. Other than that, it is a good idea. I won't use anything smaller than 3 inches on a grass field.
You might have a little more trouble with takeoffs
Cool! Looks like 3" foam wheels then!
Thanks |
| All times are GMT -8. The time now is 02:34 PM. |
