fuel lines - help!
I have just put a 46FX in my H9 Funtana and it flies great. Now I need to know how you guys hook up your fuel lines so you can get the fuel out. I have 3 lines going to my tank. 1 filler, 1 to carb and 1 to exhaust. My motor is concealled in the cowl so I cant get to the carb line to empty the tank when I am done flying. How do you do it? My filler line cannot be used to get the fuel out because the line doesnt go to the bottom of the tank.
fuel lines - help!
You have to put a clunk on that filler line down into the tank. Lot of re-work, but it's got to be there. An alternative is to install a quick fueling valve such as the great planes quick filler.
fuel lines - help!
I've never used the third line on any of my planes. On cowled planes, or RNV engines where it's just a downright pain to get to the carb line, I leave it alone. I'll put an inline filter in the pressure line just before the firewall, with enough fuel line to access it behind the engine, or above the cowl. This makes a great place for fueling and defueling by disconnecting the pressure line at the filter.
fuel lines - help!
Turn the plane upside down and de-fuel through the vent line, or stand it on it's nose and use the fill line.
Dennis- |
| All times are GMT -8. The time now is 10:19 AM. |
