hello
I am into surface RC nitro vehicles, and have been looking into planes a bit. What is a trainer?
hello
I don't mean to be rude, but you've got over 800 posts here. You know how this place works by now, do a search.
A trainer is an airplane you use to learn how to fly with...They are slower, easier to fly, and usually very simple. It makes learning go much faster... See if you can find the local flying field in your area and take a trip out there. Then you can see them for yourself and see how it all works...Seems like once the car guys try airplanes, they NEVER go back! :) http://www.modelaircraft.org |
hello
thanks for responding. My Im the time that it took to get 800 post, I learned that posting a question, gets a much more helpful response and a quicker one too. I appreciate the info. Thanks alot
Dan |
hello
hello
I was thinking something like this. I would like to build it if possible. Do you think this is alright? Give me your oppinion please
http://www2.towerhobbies.com/cgi-bin...1p?&I=LZ1996** |
hello
Replace the Air Core with a decent trainer like the Sig LT-40, Avistar, Superstar, or the Eagle 2.
With any of the above airplanes, you won't need wheels, wheel collars, or a spinner. Replace the engine with a Thunder Tiger Pro .46 (my choice) or an O.S. .46 FX... Change the prop to an 11x5 Master Airscrew and try two of those to start with...After learning, you can switch over to APC props. The wood ones are just too dang fragile and will break just from trying to start them. They are not real efficient either and you will lose a lot fo power. With a couple changes, you will have the perfect setup. |
Hmmmm....
Originally posted by BotleRocketWar I don't mean to be rude, but you've got over 800 posts here. You know how this place works by now, do a search. A trainer is an airplane you use to learn how to fly with...They are slower, easier to fly, and usually very simple. It makes learning go much faster... See if you can find the local flying field in your area and take a trip out there. Then you can see them for yourself and see how it all works...Seems like once the car guys try airplanes, they NEVER go back! :) http://www.modelaircraft.org |
hello
I see what you're saying...I guess I just saw it as asking what an engine is in the engines forum. I have always liked helping the guys that do some research on their own. dan1220 does seem like he knows more than most...I don't know what I'm getting at, so I'll quit... :)
hello
Can someone tell me what an airplane is?
hello
hello
Guys I really think the best trainer combo out there right now is the RTF Alpha trainer from Hangar 9. Check it out here: http://horizon.hobbyshopnow.com/prod...475&pc=HAN2475
hello
Originally posted by Rotcivv17 Can someone tell me what an airplane is? |
Alpha
I can vouch for the Alpha COMBO ... I've flown mine for about a month now with no real problems... Changed the glow plug, and after a small "misunderstanding" with the ground (see below), the prop....
1 piece of advice... GLUE THEM D@#* WINGS TOGETHER!!! As stated above by botlerocketwar, I think my days as a car racer are numbered... My car stuff has less & less bench space every week.... :) Good luck!! Allen |
hello
The Alpha trainer are nice and they are RTC. Another RTC if you want to jump in is the Hanger 9 Extra EZ 2. Please remember as a car guy, you will not be able to use your current Radio setup (unless you are on frequency 27 I think?). Also i learned that Air and car fuel are not the same (wanna buy a car? lol). Anyways, that all i got for pointers right now.
hello
Take the advice given so far.....Aircore planes tend to fly like bricks with wings... :D
Where in OH are you? |
hello
No offense or anything dan, but do you spend al day on this forum!??? you have 843 posts at the time of my writing this, and you registered about the same time i did. i spend way too much time on this stupid thing as it is, and i have just over 300
hello
you have 552 post :stupid: you airlplane people sure are critical. I just asked a question, and more than one person has critisized me. I sure hope not all plane guys are like this
hello
I thank you if you have helped me out, and answered my questions
hello
i haven't even payed attention to how many posts i have, i just typed down what i rmemebered. I don't mean to critisize you. To put it simply, a trainer is a plane that trains you.
hello
I think this looks pretty good. IT might be the one. I know you dont build it, but maybe this would be best to start with
Hobbico SuperStar 40 Select RTF 60" |
hello
i would reccomend a pt-40. it is a bit more expensive but for good reason. the older ones were bulky and didn't fly well. the newer ones though fly really well, aren't too mushy at low speeds, and still survive crash landings. i have ruined about 8 nosewheels on that plane, and there is no sign of fateauge. one time, i forgot to change models and i had a vtail going between the aileron and elevator. not pretty. i ruined another nowewheel in a belly landing on the runway, not a scratch. they are armored like a battle tank, but sure don't fly like one
hello
:D I just converted my PT-40 to a tail dragger. Man What a difference!!:D
hello
does the pt-40 only come in a kit? I kinda changed my mind about that part. I think for my first plane it should be an RTF or atleast an ARF
hello
Yes Dan, the Spuerstar is a really great plane. But, the Alpha takes a lot of hits, it's a balsa plane just like any other, but for some unknown reason, it doesnt break. The Superstar is pretty much like the Avistar, and I have two of those. The avistar and Superstars have a tendency to break the tail a lot I dunno why. Once, my engine shut off on the Avistar, and I tried to turn it (I was a beginner back then), and it hit the ground nose down at a full 90 degrees, and the tail broke :D.The Superstar is pretty much the Avistar, the difference is one more inch of wingspan, and the Superstar has more dihedral on the wings. Between those two, the Superstar is more of a trainer than the Avistar, many say the Avistar's a 2nd airplane. Anyways, I really recommend you the Alpha combo. Besides, it's a little cheaper, plus u get the .45 Evolution engine, great engine. And don't buy that "no break-in needed" crap, always give it it's two full tanks of break-in. Other than that, have fun with flying. Again, I recommend the Alpha :P
~Vik~ |
hello
it is an arf. rtfs are really expensive, and don't really help you learn the building skills you will undoubtedly face. arfs are great for starting to learn how these things work and how to fix them. arfs are like trainers for kits the way that trainers are trainers for harder planes.
| All times are GMT -8. The time now is 02:45 AM. |
