RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   dumb move (https://www.rcuniverse.com/forum/beginners-85/9656575-dumb-move.html)
Stick 40 04-12-2010 08:37 PM
dumb move
Hi,
I guess this is a good place to post this, I hope the other more experenced flyer will not do what I did.
I flew my Slow Poke with the .46 EVo engine, the engine flamed out on the first flight and I dead sticked it. That was not a problem, I had to adj. the needle valve and found that the little finger that keeps the needle valve in place was not touching it. In other words the needle could move on its own.
I in my wisdom decided to adj. the needle valve and fly agian ( before the wind got worse ) and took off. It flamed out again and this dead stick was not so great. Just a little damage, as I got it leveled just before touch down.
Goirish was flying with me and reminded me.
" IF IT IS NOT GOOD ON THE GROUND, IT WILL NOT GET BETTER IN THE AIR"
and thats good advice, just wish he had said it a little earlier!!!!!!!!!
sitcks
SushiSeeker 04-12-2010 10:40 PM
RE: dumb move
ORIGINAL: Stick 40
'' IF IT IS NOT GOOD ON THE GROUND, IT WILL NOT GET BETTER IN THE AIR''
Somebody told me once: Takeoffs are optional, landings are mandatory. Kinda the same thing in a way.
Lnewqban 04-13-2010 06:36 AM
RE: dumb move
It was "GOOD ON THE GROUND", but free to go bad in the air.
Rule #1: Vibration is always working to diassemble parts.
Rule #2: There are seldom situations where a flexible piece, like silicone tube, is not cure for vibration negative work.
Bonified Wingnut 04-13-2010 07:08 AM
RE: dumb move
Pull the needle valve all the way out then bend the arm before you put it back in. I've also had to put silicone tubing around low speed needle valves.-BW
MinnFlyer 04-13-2010 10:12 AM
RE: dumb move
You're taking advice from GENE???!!!
:D
goirish 04-13-2010 10:27 AM
RE: dumb move
I'm practicing to be a moderator:D:D:D
Stick 40 04-13-2010 10:29 AM
RE: dumb move
ORIGINAL: MinnFlyer
:D
Like I said I wish he had gotten mouthyer ( new word, I just made it up ) before he did. I know how to do it, just did not bother. I just did a brain dead thing.
Oh well, mostly got away with it. I don't like the engine mount on it anyway. I am going to cut it out ( made of wook ) and put a figer glass one in.
sticks
MinnFlyer 04-13-2010 10:59 AM
RE: dumb move
I think that's "mouthier"
Bonified Wingnut 04-13-2010 11:09 AM
RE: dumb move
ORIGINAL: goirish
Oohhh? I thought you were a moderator. I would listen. We need one from MI(or is that FOR MI?).-BW
MinnFlyer 04-13-2010 11:18 AM
RE: dumb move
Actually, Nathan, our Forum Manager (THE top guy in the forums) is from MI
Bonified Wingnut 04-13-2010 11:37 AM
RE: dumb move
See what I know...[:@]-BW
goirish 04-13-2010 11:42 AM
RE: dumb move
I knew he was cool. Now that answers that.
Herb Calvin 04-13-2010 06:14 PM
RE: dumb move
Here in northwest Ohio' we call that a brain fart:D
