does fuel choice effect flight time?
Hiya forum guys!
I am a new pilot and i have a question about my flight time. I am in training at a local club. I Bought a nexstar select trainer to train on, as that is what most of the instructors at the club use to teach on, and what most of the trainees have to learn on. I must admit that i find this ironic because after buying this trainer they had me take all the training aids off the plane except the speed flaps! But alas i digress. Anyway, this plane has the OS .46 engine. I am not sure about the fuel tank size, but i believe that it is either 8 or 10 ounces. I fly at about 50% to 60% throttle for most of the time. We both use the 11x5 stock nexstar prop. I use 5% nitro fuel in the plane. I am getting about 11 to 12 minutes of flight time before the tank is empty. I was fine with this until my trainer brought his nexstar selectout that has the same engine and tank as mine. We fly his for over 20 minutes at a time. When i asked him about the difference, he said," Oh, your engine just needs time to break in." I accepted his statement and moved on. At this point i have run about 8 to 10 tanks of fuel(the better part of a gallon) through the engine and I am still getting the same run times. The only difference is that the instructor uses 15% nitro fuel, and i use 5%. Our engines are tuned with the needle valve to the same pitch, so i am also assuming that the engine is tuned correctly. My enginedoes run a little richer. Should i consider stepping up to 10 or 15% nitro fuel to get these same run times? Or how many tanks of fuel will i run through this before my engine gets 20 min run times? All in all i am having a blast with the hobby and my local club has been awesome. Thanks for reading my massive run on sentences. |
RE: does fuel choice effect flight time?
I generally see excessive fuel consumption as running the engine too rich. Having trained a lot of people with the stock Nexstar I would say that a properly tuned engine should give about 13-15 minutes flight time with a 2-3 minute reserve of fuel. You could have a leak somewhere but I think I would lean the engine out a little and see how it goes. In looking at my notes I see the fuel tank is 270cc, about 9.1oz. . At about 1/2 oz per minute you should get more time. Are you sure the instructor still has the stock fuel tank? He may have forgotten he installed a larger one to give more run time for trainees. Good Luck in learning to fly.
More nitro will result in shorter flight time. With more nitro, the engine needs a richer mixture to run "right". It will sound the same, but fuel consumption will be a little higher (and it will make a little more power). My two Irvine 53s used quite a lot of fuel when new, but during the first gallon of fuel I could gradually lean the needle valve. My Four-Star 40/Irvine 53 could stay in the air for more than 20 minutes on an 8 oz tank. I agree with oldvet70; your engine might be running too rich. Most of my engines have required that both the high speed needle and the low speed needle be leaned by quite a bit during the first one or two gallons of fuel. When they get properly run-in, they run on a much leaner carb setting than when new.
Good luck, and let us know how it works out. ;) |
I did bring up the topic of leaning out the mix with him. If i remember correctly, my instructor said that running too lean will shorten the life of the engine and it was good to run with a "slightly rich" mix. He did a basic test where the throttle response was good after idling a while, then he lifted the plane and pointed it up and down and all around and it did not stall. Apparently if the engine was too rich throttle response would have been slow. If it was too lean the plane would have stalled when he pointed it all over. He does have the stock tank, it was the first thing i asked him. As far as i can tell there is no leak, but the tank in the nexstar was factory installed, and getting it out looks like it involves unmounting the engine, something i must admit i am a little fearful to do. So hopefully nothing is wrong with the clunk inside the tank or something like that.</p> |
You can adjust the high speed needle by ear quite easily. With the engine running full throttle turn it in a few clicks at a time, wait for the engine to settle into the new adjustment. Eventually you will hit a point where it will begin to slow down, this is to lean. From this point rich-en the mixture a quarter turn or so. What you are seeking is a high speed adjustment that is several hundred RPMs below the maximum RPMsetting. At this point you may have to readjust the low speed needle also. Additionally do a search for Pinch Test here in the forums for a procedure to use to verify you are not to lean or too rich. What the instructor did can be done if the engine is still too rich. You do indeed want a slightly rich setting as a lean setting will indeed damage your engine. It is possible to ruin an engine with a single excessively lean run. If you engine is properly adjusted then you need to check your fuel system for leaks.</p> |
I wa getting 8 minutes of flight time out of my lt40 before running out of fuel and i thought that was the normbecause I had a small tank for the size of the engine, ran like this for months. Turns out the low end was set far to rich.Nowafter retune flying 14 minutes and landing with fuelin tank.
8 to 10 tanks of fuel isn't really a break-in. Try it when you have had 2 or 3 gallons of fuel run through that engine. Have a little patience and I think you'll see an improvement but probably not as much as you are expecting.
Guessi am just trying to optimize my field time. My last 2 training session have been cancelled. One due to high wind, the other due to rain. Just a new guy anxious to get maximum stick time when mother nature decides to cooperate i guess. not that i am impatient, just trying to get ready and maximize the good weather days.
ORIGINAL: stang 8 to 10 tanks of fuel isn't really a break-in. Try it when you have had 2 or 3 gallons of fuel run through that engine. Have a little patience and I think you'll see an improvement but probably not as much as you are expecting. |
It should not take 2 or 3 gallons of fuel to properly break in an OS .46. It should take less than a gallon and should be giving you good mileage after just a few tank fulls. Our club was given 2 Nexstars a few years ago and I was the head instructor. I broke in the engines as called for and neither took more than 10 flights, maybe 60-75 oz of fuel. I still think you have a leak or are too rich.
Ihave an Aviastar53 that has been installed and flow on 3 different planes and it is just now starting to break in really good. Isuspect Iwill own this particular engine a very very long time.
Thats great but the OP has an OS 46 which does not require any extended breakin. I'm sure he will have it for years also.
ORIGINAL: oldvet70 It should not take 2 or 3 gallons of fuel to properly break in an OS .46. It should take less than a gallon and should be giving you good mileage after just a few tank fulls. Our club was given 2 Nexstars a few years ago and I was the head instructor. I broke in the engines as called for and neither took more than 10 flights, maybe 60-75 oz of fuel. I still think you have a leak or are too rich. Thank you Oldvet for taking the time to reply to my thread. Fly safe! |
ORIGINAL: oldvet70 Thats great but the OP has an OS 46 which does not require any extended breakin. I'm sure he will have it for years also. |
im running some of my engine 20+ min on 8oz of fuel and still landing w/ a third of a tank. most of the time at half throttle or above.
your way too rich, lean your engine till it peaks out (till you cant hear the rpm's increase anymore then back it out 1/3 ish of a turn, that should be plenty rich) your idle is harder to adjust, sit around at the field and watch people fly their planes. ask someone for help that never seems to have problems with his engines, get his advice on how to set the idle and highspeed correctly ive flown for 47min and 15 sec on 8oz of fuel before (wildcat 10%). with a gms.47 for the engine and the gp rapture as the plane. your nextar should be able to get 30+ min w/ a properly tuned engine and throttle control. |
Don't turn the needle in until the engine begins to sag. Just do the pinch test, and continue to lean the needle valve for as long as the engine picks up rpm each time you pinch. When it no longer gains rpm with the quick pinch, back off the needle to the last place it did and fly with that setting.
Fuel is cheap, engines are not. If you normally run them flat out, they lose the piston and liner fit much much faster. |
Are you able to visually see that the tank is empty? I don't think that the mixture being a little rich would cause a drastic change in flight times. My guess would be the clunk fell off and it isn't drawing all the fuel (unless you can see that the tank is dry). I've got a .46 that I always run rich and can easily get 18 minutes out of a 10 oz tank. If it was that rich it wouldn't be running remotely right.
And are you sure that the tank is really dry after your 11 or 12 minutes of flight? Can you see the tank and verify that it is indeed run dry? Or are you just assuming it is empty because no more fuel comes out the carburetor line? One common situation is that the clunk gets stuck somewhere inside the tank and you think you have run out of fuel, but really there is still some left.
ORIGINAL: DMcQuinn And are you sure that the tank is really dry after your 11 or 12 minutes of flight? Can you see the tank and verify that it is indeed run dry? Or are you just assuming it is empty because no more fuel comes out the carburetor line? One common situation is that the clunk gets stuck somewhere inside the tank and you think you have run out of fuel, but really there is still some left. I just checked and shook the plane all over, i dont hear the cluck rattleing in there...(sigh) |
A fairly easy test is to measure how much you get into the tank when filling it up and then to drain it through the fuel line to se much useful volume that you actually have in the current setup. There might be errors both in the vent position and in the fuel draw/clunk.
If the engine runs well, don't change the setting. |
The difference in flight time can also be in the way two individuals fly. If one is running flat out most of the time and another is generally cruising and only throttling up for climbs and manuevers, the one who is using less throttle for the majority of the flight is going to use less fuel per minute and thereby experience longer overall flights with the same amount of fuel.
In my experience I've noticed that my warbirds run out of fuel relatively quickly from maiden through the first 8-10 times out. After that the flight times increase substantially and max out after about the 15-20th flight. I know it's a factor of throttle use since the engines are always proven and well broken in and the fuel type stays the same. It's a matter of my keeping the speed way up while I'm getting comfortable with the plane and determining it's personality, once we get well aquainted fuel consumption eases up since I'm not keeping it wide open, or close to, for most of the flight. In some cases my flight time can more than double as half throttle is discovered to be plenty for level flight once the powercurve and energy needs for a particular airframe are learned and aerobatic throttle management get smoother as the "tinglies" wear off with the new plane. Those newer to the hobby tend to show the same type habits, keeping a lot of juice on. As your skill set develops and you become more comfortable with flying, your throttle management will get better and yield longer flight times. Two areas where a lot of fuel is consumed unneccesarily is being "late" backing off the gas coming out of the backside of a loop, and "jack-rabbit" accelerations as opposed to smooth power increases. Both of these can really gobble up the fuel. If all of your settings and set-ups check out then I would suspect that this is your case. Even if you find a set-up issue in this case, I think that over time you'll notice that there seems to be more fuel in the tank than you expected at the end of your flights and you'll begin to stay aloft a bit longer and longer. Welcome to the hobby, happy flying:D |
I didn't read each post in this thread, however, one point is that fuel does three things.. of course, the obvious is that it burns to run the engine.. :eek:;) , it lubricates the engine, and it cools the engine.
Running to lean will cause the engine to run hot and it will not provide enough lubrication.. both of which is how a lean mixture will ruin an engine. So, the compromise here is to have the mixture just right so you get the proper burn, good power/RPM, and that the engine is sufficiently lubricated and cooled. CGr. |
My trainers would run 20 minutes or more on a tank of fuel but I'm not able to concentrate on flying for that long. After 10-12 minutes, my neck hurts from looking up, and I start feeling pretty uncomfortable overall.
Most of the people in my club set a timer for 10 minutes and land pretty soon after it beeps. Even though your engine is running well, if your run time is that much shorter than your instructor's, it is running richer than his. |
IMO I think your engine is just running a bit rich. Or simply you have a engine that uses a bit more fuel. As a instructor myself, I agree with CARRELLH, about 10 minutes is all you want in a flight at one time when learning. Many fliers who are not a regular instructor trying to help other people to learning to fly tend to fly the trainers way too fast. Once a trainer reaches safe altitude you can usually throttle back to 1/2. When I plan to fly my glider (30 minutes+) or any aircraft over 15 minutes, I bring out a chair so I can sit in.
OP: I have the same plane, same setup. I have maybe a gallon through the engine and I get 20mins + out of a tank all day long.
I have a Nexstar, when you are finished flying, before you defuel it, take the wing off and hold the plane vertical, and see how much fuel is left.
ORIGINAL: Puff The Magic Dragon I have a Nexstar, when you are finished flying, before you defuel it, take the wing off and hold the plane vertical, and see how much fuel is left. |
The fuel tank can be seen from the cabin area. It.s not built into the plane. It is installed from the back, not the front.
To know how much fuel you have, go old school.
I now use a manual hand pump specifically for this - and have ditched the electric pump that makes a god awful noise. When you fuel, count how many turns it takes. One plane I have takes 30ish turns. Once landed after 10 minutes, I defueled and found it took 10 turns to empty. So roughly a 15 minute flight time. |
well.. . after a weekend of trying to get this sorted out, I think i have given up. At 50% throttle, with some revs and idles, looks like 14 min is the max i am going to get per tank.
I have pulled the tank and checked the clunk and the seals. No leaks. I did gain a full 2 mins by leaning out the mix. I am running 3 clicksrich from max rpm. Any other ideas about why other get 20-25 mins and i get 14? |
Try a 11X6 prop. You currently have the pitch for climbing and aerobatics. The 11X6 is more suitable for cruising around.
Running in with these ABC and ABL engines is a lot quicker than most people think. A GMS 2000 47 is considered run in within 30 min of first running it. A OS 46 Max AX is run in after the first tank and youhave followed the rich / lean procedure they describe in the manual. thereafter you can fly th motor in. the fuel consumption wonltchange much from aftet thatfirst tank till the day it dies if you have the low speed settings correct. I have seen many people blame deadstick landings on everything from fuel to plugs to atmospheric conditions. true sometimes those are copntributing factors but 9 out of10 times its the low speed settings that too rich. Too rich and the excess fuel takes heat out of the combustion chamber and the plug just dies. Check you settings. Startmotor and progressivley open the throttle to full. now dow the pinch test. The motor should immediately pick up speed before wanting to drop revs and cut out. Now drop the revs to idle. Pinch the carb feed again the motor should run normally for around 3-5secs before starting to choke off. release and it should recover revs. If it is still on high idle after 6secs then you are running it too rich on the low speed needle. Running the engine rish can also lead to plug and combustion chamber fouling. This leads to higher fuel consumption. start off with your engine settings.</p> |
ORIGINAL: TimBle Running in with these ABC and ABL engines is a lot quicker than most people think. A GMS 2000 47 is considered run in within 30 min of first running it. A OS 46 Max AX is run in after the first tank and youhave followed the rich / lean procedure they describe in the manual. thereafter you can fly th motor in. the fuel consumption wonltchange much from aftet thatfirst tank till the day it dies if you have the low speed settings correct. I have seen many people blame deadstick landings on everything from fuel to plugs to atmospheric conditions. true sometimes those are copntributing factors but 9 out of10 times its the low speed settings that too rich. Too rich and the excess fuel takes heat out of the combustion chamber and the plug just dies. Check you settings. Startmotor and progressivley open the throttle to full. now dow the pinch test. The motor should immediately pick up speed before wanting to drop revs and cut out. Now drop the revs to idle. Pinch the carb feed again the motor should run normally for around 3-5secs before starting to choke off. release and it should recover revs. If it is still on high idle after 6secs then you are running it too rich on the low speed needle. Running the engine rish can also lead to plug and combustion chamber fouling. This leads to higher fuel consumption. start off with your engine settings.</p> |
[/quote] I know on the 46 AX there is the high speed needle... how do i change the low speed settings? [/quote] The low speed needle valve is inside of the throttle barrel. It takes a small screwdriver. |
The low end setting is probably your culprit. Do you get a lot of residue on the side of your plane? An engine rich on the bottom will blow raw fuel out of the muffler when you gun it from idle of just off idle. It'll also constantly spit fuel when cruising at low throttle settings.
1 Attachment(s)
This illustrates the LA series, but the AX is similar, you'll find it on the throttle arm side of the carb recessed in the barrel.
This is one of the reasons I sold all my IC engines and went all electric. To much fiddling. With electric, I plug it in and fly, when I finished flying, I don't have to clean the mess of my airplane.
ORIGINAL: Puff The Magic Dragon This is one of the reasons I sold all my IC engines and went all electric. To much fiddling. With electric, I plug it in and fly, when I finished flying, I don't have to clean the mess of my airplane. Once upon a time, we really enjoyed ALL the facets of this hobby beyond being test pilots of delicate humming aircraft's. Fiddling IS the hobby for some. It's rewarding to overcome obstacles and learn from them, gaining experience that reflects in thousands of forum posts here to help others, yet another part of the hobby that shouldn't die out. Finding an idle screw and it's function, is hardly reason to abandon glow engines! Today finding an old kit is another activity that precedes the building phase, where "fiddling" with building tools, glues, fillers, and covering materials to achieve a beautiful model I built myself. Fiddling with fuel, props, plugs, tuning, exhaust options, (some even get internal and modify their engines for more performance) are more rewarding practices found in this hobby than RTF EP piloting. Electric certainly is a shortcut from fiddling with glow power. As far as avoiding messy clean up chores after flying, one could fiddle with exhaust extensions or engine position to point exhaust oils away from their model and be just as clean as the delicate humming aircraft's out there. I wouldn't want to restrict myself from the joy of watching my creation have a beautiful flight, and do so for over a decade without fatigue or failure. EP isn't all gravy, some suffer li-po fires, fry speed controllers, having bulging batteries from overcharging or worse, and pay more for their charger than I do for an engine. To each his own. Maybe if they fiddle with it, they'll get it right? |
I have been modeling since 1974. I'm not losing anything, I scratch build 80% of my planes, (Instant Gratification, I don't think So) I also have some ARFs. I still paint my planes. It is just painful for me to kneel on the ground to start & adjust Nitro engines. I took a fall while working on a Motor Grader & totally mess up my back. I'm a Retired( Not By My Own Choice) professional Mechanic. As far as working on my own car, unless you invest the money into the scan tool, you can't figure out whats wrong with it, unless you drive a dinosaur. You can start swapping parts and hope you hit the right part. The days of shade tree mechanic are gone. Just like changing your own oil, it's a lost cause. By the time you buy the parts, find a place to recycle your dirty oil, add in your time, your losing money. Do you check all your fluid levels when you change oil, do you vacuum the car, get a free car wash, and be done in 20 minutes all for 30 bucks. As far as my charger goes, it will charge any battery out there, from Lipos to my car battery. I use it to cycle my transmitter batteries, flight pack batteries, yes I still use them on larger Electrics
ORIGINAL: Puff The Magic Dragon I have been modeling since 1974. I'm not losing anything, I scratch build 80% of my planes, (Instant Gratification, I don't think So) I also have some ARFs. I still paint my planes. It is just painful for me to kneel on the ground to start & adjust Nitro engines. I took a fall while working on a Motor Grader & totally mess up my back. I'm a Retired( Not By My Own Choice) professional Mechanic. As far as working on my own car, unless you invest the money into the scan tool, you can't figure out whats wrong with it, unless you drive a dinosaur. You can start swapping parts and hope you hit the right part. The days of shade tree mechanic are gone. Just like changing your own oil, it's a lost cause. By the time you buy the parts, find a place to recycle your dirty oil, add in your time, your losing money. Do you check all your fluid levels when you change oil, do you vacuum the car, get a free car wash, and be done in 20 minutes all for 30 bucks. As far as my charger goes, it will charge any battery out there, from Lipos to my car battery. I use it to cycle my transmitter batteries, flight pack batteries, yes I still use them on larger Electrics I have a bad neck and suffer headaches after I look up 15 minutes at my plane. I try to fly bigger planes and at a distance so I can look straight. It doesn't stop me. I start my planes on a table or on the tailgate of my truck, who bends over anymore? Puff, I know you are a seasoned modeler, that name / song dates you! I wasn't trying to insult you. But a sore back is no excuse to give up glow. An airplane stand fixes that instantly. You can switch to combat planes and hand launch them. I have a 2005 F-150 and I do change my oil at a savings, it holds 7 quarts. My kids wash my truck, clean my planes, cut the grass, do the dishes, and fold their own clothes for their cell phone service. I do my own brakes, $25 a set, instead of shelling out $400 and having work done that I didn't need. I do my own work so the stupid Jiffy lubers don't over tighten my drain plug, or forget to oil my filter gasket, or worse, forget to get the old one off the block! I get to see what my truck looks like underneath, catching problem signs early. Pistons are pistons, I can replace them just like a 350 Chevy but with today's oil, I'm expecting 200,000 miles of service or more. Dinosaurs are great cars, but today this truck's sensors tell me where to go to fix the problem. I get it scanned free at Auto Zone. I'm saving money. Everyone knows mechanics mark up their parts ridiculously for more profit, and I love the "shop supply" fees, disposal fees, and $2.50 an extra quart of oil over 5 quarts. I thought li-po cells needed to be charged with a balancer or balanced charger costing $50-100? |
I will say that I have gotten 2 new OS 46ax's this year. I found both of them to be set very rich on the low end from the factory. I think you need to lean out your low end and see what happens.
| All times are GMT -8. The time now is 04:50 PM. |
