RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Idea for someone to run with. (https://www.rcuniverse.com/forum/beginners-85/9828119-idea-someone-run.html)
tripower222 06-26-2010 01:00 PM
With the new A123 and LiFe RX batteries (which eventually most will be using) the only issue I see is the flat voltage drop until its almost too late. Someone needs to develope an item similiar to the volt watch in size, only its a mah usage meter/readout (like many chargers have) with a resetable nonvolitalile memory. And heck why not put a volt reading on it also.
Then you might know where you stand.
CGRetired 06-26-2010 05:24 PM
RE: Idea for someone to run with.
Ummm yeah.. there must be some electrical engineer that can design this.. make it small enough to put in our planes, and cheap enough for us to afford... ;)
Just teasing. But, you make a good point.
CGr.
w8ye 06-26-2010 06:16 PM
Even a resetable power used meter?
exeter_acres 06-26-2010 06:56 PM
two points...
No comment.......
and Fromeco has a switch (or at least had....) that would show how many mAh were taken out of the pack during a flight.
w8ye 06-26-2010 07:26 PM
I think the past tense "HAD" is more appropriate
ggroyal1 06-27-2010 09:39 AM
1 Attachment(s)
Fromeco use to sell the Kodiak switch with ma counter.
Looks like a very good setup for A123 batteries.
w8ye 06-27-2010 10:04 AM
The Kodiak line is no longer on the menu
It is now just Badger or Wolverine
http://www.fromeco.org/categories/switches/
tripower222 06-27-2010 01:52 PM
ORIGINAL: ggroyal1
I like it
ggroyal1 06-27-2010 02:16 PM
1 Attachment(s)
I sent an email to Fromeco asking them to bring back the Kodiak and Weasel.
I have the Weasel in one of my 50cc planes with A123 batteries. I works great and keeps up with the amount of current used, it does not reset when powered off.
The only problem is you have to remove the canopy to see it.
Mikecam 06-27-2010 02:41 PM
http://www.voltmagic.com/
You can buy it here. http://www.hangtimes.com/chargers.html
Works just like the voltwatch for nicd and nimh and shows a few other important things as well. Mine gives me great piece of mind.
ggroyal1 06-27-2010 08:14 PM
I received an email from Fromeco today and they are bringing back the Kodiak and Weasel.
They do not have a date at this time.
