RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Throttle servo vibration/stringer contact? (https://www.rcuniverse.com/forum/beginners-85/9871607-throttle-servo-vibration-stringer-contact.html)
ro347 07-17-2010 11:29 PM
1 Attachment(s)
In the process of rebuilding a Funtana x100. I installed the throttle servo, yet seems the servo sits right on the stringer under it. Would this pose a problem? Im thinking of vibration being transferred from the frame to the servo.
Charlie P. 07-17-2010 11:54 PM
RE: Throttle servo vibration/stringer contact?
Might. I'd back it out and put some two-sided tape along where they meet so at least it's dampening the contact.
ro347 07-18-2010 12:15 AM
Thanks Charlie. I just wanted to confirm that it might be a possible problem. Ive recently lost 2 throttle servos over the last few months due to vibration ( Hitec HS -82mgs). The servos werent designed for the vibration, but its fresh in my mind so just dont want to have to deal with it later. I will probably add a little ply and raise the servo up 1/8 of an inch.
thanks
CGRetired 07-18-2010 05:17 AM
Yeah, if you have the room, that's what I would do.
CGr.
DavidAgar 07-18-2010 09:08 AM
You could also glue some 1/8 inch ply on the top of your mounting which would completly lift your servo of the beam. Good Luck, Dave
