brushless help in easystar
Hi everyone
i have just bought an easystar for fpv flying and im wondering if i can use an old brushless setup i had in a old stryker i built?
Its a 400 size like the stock but its got JP EnErG brushless (A2815-6 1400RPM/V) on the motor and HiModel FLY-33A on the esc with a 6x4 prop, i ran this on a 2100Mah 3cell 20c Lipo in the stryker until it crashed
Ive also got a Brushless-motor Bm2409-12 outrunner with a Hi-Model FLY-25A esc and a 7x5 prop which i used in an old aerobird extreme (more like the easystar i guess) but i will need to make a suitable mount if i use this one?
Any advice will be greatly appreciated.
TN
RE: brushless help in easystar
1400Kv or 1600Kv and a 6x4 on 3s won't get you a lot of power (2200Kv is about the norm). You can try a 7x5 on the 2409 (and have to modify the mount to get prop clearance) but even that won't be particularly potent.
However, either of those will be better than the stock brushed motor... so why not!
thanks bud.
im only flying it for fpv so dont need it to be crazy fast, just better than stock with longer run time.
