PROBLEM WITH GEAR DRIVE!
I have a Vermont Belle 1300 with a Himax 2825 / 3643 motor. When applying power, the torque of the motor will cause the motor to separate from the gearbox. This is a big problem since it twists the wires and spews the gears inside the airplane. Has anyone discovered the secret to keeping high torque motors from twisting (separating) themselves off their gearboxes?
Frank
Frank
My Feedback: (21)
RE: PROBLEM WITH GEAR DRIVE!
The gearbox instructions should include a step that describes how to fasten the motor to the gearbox.
What may be necessary is simply a wrap or two of electrical tape to make the gearbox/motor fit tighter.
What gearbox are you trying to use?
The gearbox is a Promaxx 4.3:1. I like your idea about simply using tape and I'll also use some blue Loktite.
Frank
Frank
