Multiple engine setup
My Feedback: (8)
AB, CANADA
Ok I may be getting in way over my head but I came across a plan for an electric C130. Spec'ed for 4 x Speed 400 motors turning 6x3 props and using a 10x 1.7Ah battery pack. Now I am new to electric planes and thinking of this as a future project. Exactly how does this get wired up. Can 1 speed controller work for all the engines? (running in parallel) or do I use 4 controllers. What gear ratio would work? Just trying to figure out a cost of what I'd need.
My Feedback: (21)
RE: Multiple engine setup
You can wire up the motors any way you want to. All four can be on one ESC, provided it's large enough to handle the load. They can be on separate ESCs. Then you could also run 2 ESCs, with 2 motors on each. You could also one 3 motors on 1 ESCn and one on another, though I have no idea why you'd do that... This is for BRUSHED motors, like your Speed 400s, ONLY.
When they recommend 10 cells, they're almost certainly talking about 7.2V Speed 400 motors. There's a signifigant difference. IF you used 6V Speed 400s, they'd burn out quickly.
A 6x3 propeller would be direct drive. I suspect that your limiting factor for propeller size will be the distance between the motors on each wing, or the distance between the inboard motors and the fuselage. You probably can't get much more than a 6" prop in there, so gearing wouldn't gain you anything.
My Feedback: (8)
AB, CANADA
Thanks Matt
On the 10 cells, would it be 10 cells setup as a 12V pack or 2 - 6V in parallel. Might be silly questions but I'm new to electrics.
Dave
Dave
