How battery with Axi 2208/34 and Phoenix 10
Dear sirs,
I have a Ikarus 330s with an Axi 2208/34 on it , phoenix 10 and APC 10X3,8 prop. I´d like to know wich batery I do have to use on this configuration ? I´d to use a Li-Poly that takes me to flight at about 15-20 minutes...
Érico Gaiotto
Érico Gaiotto
My Feedback: (21)
PA
RE: How battery with Axi 2208/34 and Phoenix 10
13000 mah is quite a big pack. What does that weight 15 pounds. You can run a 3 cell pack with a CC10 and a 10X3.8 prop. Use a Thunder Power 3 Cell 860 mah. It is good for a 10 C discharge and 12 burst. Try a 9 x 3.8 prop to. little more thrust and over 1 amp less draw.
I am using this motor prop and esc on my hell raiser. I am using an 830 3Cell Lipoly. It generates about 20oz of thrust, and lots of flight time.
Guys,
I think a 1300mha battery is too big, I choose to use a 830 3 Cell. For a hover procedure, what location should I put this battery on my shock flyer, I heard that someone put it back on the wing,What do you think?
Thanks for all replies,
Gaiotto
Gaiotto
