Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Axi 2204/54 Current Draw / Battery End State?
Old 01-05-2005, 10:04 PM
sillyness
My Feedback: (25)
sillyness's Avatar
Default Axi 2204/54 Current Draw / Battery End State?
Hey folks,
My setup:
Axi 2208/54
Phoenix 10
Kokam 340 mAh
APC 8x3.8 prop
What kind of current are you drawing with this setup? I see folks are using 4 amp speed controls with this motor, but I drew around 4 amps just hovering... I'm sure it would be higher at full power (probably around 7 amps) but the thin wire in my jerry-rigged test setup caused too much of a voltage drop and my ESC kept cutting out.
Also... what is the no-load voltage of your batteries when you're done flying? Mine seem to be around 7.35 volts when my ESC starts cutting out, indicating a significant voltage drop under power. With another Phoenix 10 and an AXI 2208/34 I have the voltage can be around 6.5V no-load when done flying (same battery). I'm charging the battery right now to see how much goes into it... I'll let you know.
Old 01-06-2005, 10:48 AM
sillyness
My Feedback: (25)
sillyness's Avatar
Default RE: Axi 2204/54 Current Draw / Battery End State?
Battery too 265 MaH after starting to cut out.
Old 01-07-2005, 10:09 AM
jooNorway
Some datas on the bottom of the page: http://www.mft.nu/motors/borstl/axi/2204/axi2204-54.htm You did say 2208/54...?
If you draw 7 amps you are on the hard side of running this cuite...!
And if you have a PHX-10 just adjust the cut-off and forget all the other ESC`s on the market! You didn`t say if you use 2S or 3S LiPo... The recommended cut-off voltage is 3Volt pr. cell for LiPo`s! (I use 2,5 volt, but it is NOT recommended!! Haven`t destroyed any LiPo this way yet... 6 of mine old 3S700 E-Tec`s have been threated this horrible way 150 times each and still works good, but NOT recommended)
Old 01-07-2005, 12:51 PM
affas
affas's Avatar
Hello JOO !
Seems like I have to try one of this. Looks nice......
Old 01-07-2005, 01:18 PM
jooNorway
I`ll try too affa Delicious gadget!
Indoor tomorrow! (Pocket-Walley...)
