HIMAX motor repair
OK
HIMAX motor repair
Well, I am not sure if I am in the right forum area and I am sure that I will be moved if I am not.
Question is that I have a Himax (2015-4100z) brushless motor that is geared and I got into a bit of trouble when I didn't put that silly tiny little $.01 screw in the block and then went flying. Yep, it came off and twisted the motor and the wires. (Oh, this is the second time I had twisted the motor and wires but the first time it all worked. Why don't ailerons work well in reverse?) Anyway, the red wire on the back of the motor is by far broken.
On this type of motor, how do I get access to the wires to do a repair or am I !QUOT!crap out of luck?!QUOT! I am not sure if the back will pop off or the front when the output shaft screws off.
Thanks for your time!!!
CA
RE: HIMAX motor repair
Wierd..I posted a reply yesterday and now it's gone!!??
Anyway, if the wire is broken off inside the case, you may be SOL. If there is a little bit left sticking out of the case you may be able to save it but it takes either a solder pot or some tedious wire insulation removal with a dremel and a wire brush attachment. Take some pics and post them here or email them to Himax. They're pretty good with responding to emails in my experience.
CA
Is that a joke or did you delete it? I gave the same advice here??
I'm not sure how the moderation goes in these forums since I see some pretty nasty exchanges in other forums.
OK
Well, I had a little bit of the wire showing out of the back of the motor. I had a friend of mine try and fix it and he stated that it was a pain. He said that everything that he did with trying to solder it failed. He said that the wire just wont take solder and he tried really high heat. He did give it back and said try it and It just would not work. I pulled back the job he did and it just fell apart. I guess that I probably am SOL. I appreciate the advice though.
CA
The reason solder won't stick to the wire is because it has high temp insulation on it and you need to clear it away to have solder stick. You need to either go strand by strand and strip the insulation off, use a wire brush on a Dremel, or dip it in a solder pot (which basically melts/eats the insulation off). I feel your pain, I've had this exact same thing happen. Try and contact Maxx Products or who ever you bought it from. They may have a solder pot or a way to repair it. Maybe a nice individual around here would extend their services, you never know. That's why I mentioned to take pics and post them here.
OK
Thanks Troy-RCU for the advise. When I mean there is a "little bit of wire" sticking out, I mean a little. .021in to be exact. So I will probably go a head and get a new one. Heck I will most likely shop here on RCU.
Again, Thanks Troy-RCU for all the help.
