advance 40 opto plus
IN
I'm installing my new Jeti advance 40 opto plus in my plane. this esc doesn't have a bec...do I need something to reduce the current to my receiver to power my servos?? and if so what do I need...Thanks,,
My Feedback: (14)
ON, CANADA
RE: advance 40 opto plus
If the ESC has no BEC, you simply power the receiver with an ordinary flight pack. What you use, 4.8V or 6V is up to you. The alternative is to buy a separate device to use the motor battery. If you can afford the weight, and since you are using a 40 amp ESC I assume you can, use a separate flight pack. That way you are not doomed if the LiPo dies on you in flight.
