Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
REVERSING MOTOR SHAFTS
Old 08-04-2007, 11:59 AM
cajun1
Default REVERSING MOTOR SHAFTS
Can someone explain how to reverse the shafts in a United Hobby/Hextronic brushless motor #3536.
I have loosened the set screw that should let the shaft come out, but nothing moves and I don't like to force parts on new motors.
I need to mount this on the front of the firewall and it comes apparently set up to mount on the rear of the firewall.
Old 08-04-2007, 08:54 PM
cajun1
Default RE: REVERSING MOTOR SHAFTS
OK, I found the problem.
I was thinking collet type prop adapter, and found Hyp uses a bolt on prop adapter on this motor, so the long end of the shaft goes out the rear. First time I've seen this.
It would help if some minimal instructions were included with the motors.
