removing switch from esc
I have a on/off switch on my esc I want to remove. Do I just cut the red/black wires and solder them together?
cheers
clovus
cheers
clovus
Banned
My Feedback: (9)
RE: removing switch from esc
ORIGINAL: clovus
Anyone?
Guess I'll just have to try and see huh?
clovus
Anyone?
clovus
Thanks for the reply Red,
I was wondering why some escs have them and not others? Why not just disconnect the battery? It is a 12A esc, on a 3D profile. Seemed a good and easy way to save weight.
clovus
clovus
BC, CANADA
What link of heavy duty switch do you use?
ORIGINAL: Red Scholefield
Should be no problem, but you should provide a convenient way to disable the system. I use a heavy duty switch in the main power line between the battery and ESC. On ESCs that have a switch I just leave the switch on and tucked somewhere inside the plane.
ORIGINAL: clovus
Anyone?
clovus
Anyone?
clovus
Banned
My Feedback: (9)
ORIGINAL: bobferguson
MO
So the battery plugs into the switch and then from the switch to the esc? how is the switch mounted to the plane? Also do you have any pictures of the switch and how it is mounted. Thanks Dennis.
MO
Ok Thanks Red, I see how you mounted the switch on your plane, what would you suggest on a foam plane. I am currently just connecting the battery straight to the esc, with deans connectors. Have to be very careful of the throttle, so i dont cut a finger or something. Thanks Dennis.
Banned
My Feedback: (9)
ORIGINAL: skywalker
