Larger motor?
CO
Larger motor?
How does one know what the largest motor is (in physical size) I can put in this plane?: http://www3.towerhobbies.com/cgi-bin...?&I=LXRPD6&P=0
Mike
Mike
CA
RE: Larger motor?
Mike,
Medusa makes the right size motors for this plane. If you change the stock fans to five blade the plane will scream. Use a 2100 3S pack and you can get about 10 min flight times depending on how you fly.
Jeff
Jeff
TN
RE: Larger motor?
ORIGINAL: jmohn
Mike,
Jeff
Mike,
Jeff
Aren't those brushed 300's, in the EDF 64, ~24mm in diameter? The replacement GWS005 brushless motors are 20mm. Medusa makes 12mm, 28mm and 36mm!
Any number of 20mm motors will fit, but perhaps this new housing permits the use of a 28mm motor (nice of them not to bother to give you the size of the "larger hole"!!!) http://www.bphobbies.com/view.asp?id...6&pid=NGWS7204
