Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
compare these motors
Old 11-16-2007, 01:12 PM
dammitman
My Feedback: (15)
Default compare these motors
how do these motors compare? i am wanting to get a Great Planes® Seawind® Seaplane EP ARF. it suggests using the 28-30-950 out-runner brushless rimfire motor. i have a AXI 22-12-26 already and am wondering how it will compare and fly the plane. does anyone have any idea? any help is appreciated.
Old 11-16-2007, 07:02 PM
Dr Kiwi
Default RE: compare these motors
In bench tests those two motors generated very similar numbers - since you have the Axi already, go with it - it is a higher quality motor and can be pushed a bit more than the Rimfire without getting hot. Both are limited to ~14-15A on 3s (the Rimfire became hot fast at 16A, and an immersion heater at the suggested 20A surge current).
What size prop does the Seawind require?
Old 11-16-2007, 08:30 PM
pilotpete2
pilotpete2's Avatar
I would also go with that AXI
Just be aware that you will have to do some modification to the motor mount on the Seawind as the gRimfire motors use a 3 bolt pattern[:'(] rather than the normal pair of 16mm and 19mm spaced holes. I had to make my own motor mount to use a 22--12-34 AXI on the GP S.E.5a.
I am also about ready to pop for the Seawind, but in my case it will be more of a Snowind, somehow I think it may be a blast flying of fresh powder[8D].
Good luck and please post your progress if you do get one soon.
Pete
Old 11-16-2007, 09:17 PM
wings 540
anyone know if a Seawind would work with an e-flite park 480? as I too want one.
Old 11-17-2007, 05:01 PM
Dr Kiwi
ORIGINAL: wings 540
I'm not sure if the Park 480 would draw enough current with only the required 8x6 APC SF, though perhaps it will - both the Rimfire and Axi are even lower Kv than the Park 480's 1020Kv. I'm guessing they'd draw ~12A with that prop. If you want more 120W of power you really need to get a slightly higher Kv motor.
Personally I'd forget the 8x6 APC SF and use an 8x6 GWS HD - almost the same thrust, at better pitch speed, for only 3/4 of the amp draw/watts-in!
