Magnet glue??
What type of glue is best to reglue outrunner magnets? Also, any tips for rebalancing? Has anyone tried a prop balancer on an outrunner housing?
Or a good quality slow epoxy.
Glueing in magnets
http://www.torcman.de/index_e.htm
-> downloads
-> Assembly Procedure TM280, 350, 430
-> chapter 3
Vriendelijke groeten
Ron
Glueing in magnets
-> downloads
-> chapter 3
TN
ORIGINAL: speedy72vega
Thanks guys, I appreciate the responses. The outrunner i'm talking about is a large one, a 50-65, so I think the JB Weld might be the best choice. What about balancing afterwards? Anyone balance one before?I think the reason the magnets came loose in the first place (other than it's a crappy Turnigy motor) was due to improper balancing. It vibrated and screeched, then the magnets started coming loose.
I wonder if a magnet was loose from the start?
JB Weld sounds like a great choice. Be sure you don't let too much adhesive build up beneath the magnet. The spacing between the magnets and the stator is probably quite small, and you don't want the magnet rubbing on the stator.
- Jeff
ORIGINAL: jdetray
- Jeff
- Jeff
I think it wasn't balanced well, and the vibration loosened the crappy glue (it was a cheapo Turnigy motor). Too bad, because if the motor had been made better, it seems to have good potential for power.
