whats the different between this 2 motors
hi
im searching for A4120/7 Motor
i found 2 but i dont know whats the best as speed/torque/battrey life etc...
because im using different airplanes size 50 to 60
take a look
http://www.gliders.uk.com/prodinfo.asp?number=JAM134120
http://www.e-modelisme.com/a41207-br...acturers_id=30
is there any other different than how it looks?
Q8
take a look
Q8
RE: whats the different between this 2 motors
I couldn't get to the second site, but if they are the same size and both 610rpm/v and 41milliohm then yes they should perform at least close to the same.
the 1st one magnum Motor output 1100 Watt
i will send them email asking them about the 2nd one output
but which Watt better if its more or less than 1100Watt?
1100 watts is peak power and somewhat subjective. Don't expect more than 500 to 600 watts continuous. Most 4120 size motors are .25 to .40 glow equivalent, good for a 5 pound sport plane.
TN
Those are both the same... they are Suppo motors. http://www.suppomodel.com/
