"C" Rating on LIPOS
My Feedback: (90)
"C" Rating on LIPOS
Hello,
What does the "C" rating mean? What is the difference between 15C and 30C?
How do I determine what C rating I need for my application?
Need to power a 92mm DF with a 7 blade, agressivly pitched rotor.
Conidering 6S or 7S with a 1500kv brushless inrunner.
I'm very new to the electric birds but I want to learn so go easy...
RE:
Discharge "C"apacity
If you have a 2000mah battery thats rated at 10C you can get 2000 * 10 = 20000 mah / 1000 to convert to amps or 20amps
The same battery with a 25C rating could deliver 2000*25= 50000mah or 50amps continious without overheating and puffing.
If your application requires or pulls 40 amps then the 10C battery wouldn't cut it but the 25c battery would give you a safe overhead.
As for calculating amp draw from a specific power system I'll let someone more experienced with that comment.
AZ
RE:
I agree with Andy. But, remember a 2000 mah battery can only supply 2000 milliamps for an hour or 2 amps per hour. This would be considered "1C", if you draw 10C from the same battery it will only last 1/10 of an hour or about 6 minutes. Your should never run your battery completely down or out. This could damage the battery.
