Parallel MAH?
Not sure if this is the right place to ask this, but I am sure someone here can answer.
My question is, if you run 2 or more batteries in Parallel, how do you figure the MAH capacity? Say if I have 2 800 mah lipos, and I wire them in parallel, do I essentialy have a 1600 MAh battery, or is there another formula to figure this out? Thanks, jeff |
RE: Parallel MAH?
Nope, its pretty simple.
Series adds voltage and maintains capacity. Parallel adds capacity and maintains voltage. |
RE: Parallel MAH?
