Any prop adapters fit most motors?
i got lots of motors 380's,400's , is there a prop adapter i can use with those motors. i dont wana use gearboxes and spurs. Any prop adapter that tightens a prop directly to the motor?
RE: Any prop adapters fit most motors?
yup, heres some, you can find these other places too, and maybe even at your hobby shop
http://www.allerc.com/index.php?cPath=36_61 |
You just need to know the diameter of the shaft...
don't forget that you usually can't just remove a gearbox and pop on the same size prop.... the gearbox allows the system to produce more torque.... depending on the motor, you usually need to go with a smaller prop if you use it as a direct drive....... |
