IPS power system, could it handle 3 lipos?
I bought an IPS power system , the add says: GWS IPS POWER SYSTEM THAT HAS A GEAR BOX. IT SWINGS UP TO A 10.47 PROP. GREAT FOR THE FOAMIES THAT IS FLOODING THE MARKET TODAY.A 7 OR 8 CELL NIMH OR NICAD OR A 2 TO 3 CELL LIPO PACKS WORKS WELL WITH THIS POWER SYSTEM.
the only difference i see between it and the ips i use for my pico tiger moth is it says ips power system A on it. mine had letter S on it. is it true it can handle 8 cells or 3 lipos,and prop 10.47? |
RE: IPS power system, could it handle 3 lipos?
Normally you should run the 2 cell lipo on the IPS motors. You could run a 3 cell but you will probably burn the motor up in a few flights. The 7 or 8 cell Nicd and Nimh will work fine.
Bevo |
If you look at this link, you'll see that the highest voltage GWS recommends for that motor is 8.4V. You'll get results as stated above.
http://www.gwsus.com/english/product...system/ips.htm |
Actually, lots of people successfully fly IPS motors on 3S lipos. The key is to choose a gear ratio and prop that keeps the amps down.
[link=http://www.google.com/custom?q=Deaninmilwaukee+ips+%223s%22&sa=Google+Se arch&cof=AH%3Aleft%3BLH%3A72%3BL%3Ahttp%3A%2F%2Fst atic.rcgroups.com%2Fforums%2Fimages%2Frcgroups_log o.jpg%3BLW%3A203%3BAWFID%3A1e8162890817fdb8%3B&dom ains=www.rcgroups.com&safe=strict&sitesearch=www.r cgroups.com]Click here for a Google search[/link] with lots of links to this very subject. - Jeff |
Jeff,
It has always been my understanding that the smaller can motors can't handle the high speeds at which they turn, regardless of the amp draw. What kind of life do people get out of these IPS systems on 11V? |
Look in the other forum for posts by "DeaninMilwaukee" who seems to be the expert on running the IPS on 3S lipo. He reports getting 15-20 hours from the motors. He uses heat sinks on the motors, of course.
- Jeff |
