motor controller w/out reciever?
hi, first post!!
i have a general question reguarding brushless motor speed controllers. is it possible to use one without the reciever? could you ,for example, put a pot inbetween signal and ground to control the speed of the motor? ive seen a couple cheap ones on ebay id like to experiment with, and i dont want to build my own 3 phase converter. thanks |
RE: motor controller w/out reciever?
That won't work because the speed is controlled by a pulse train from the receiver. There are several servo testers that will do it however. One from Astroflight for $19.95 that works fine.
http://www.astroflight.com/store/sto...dCJE94bN49l9S1 |
If I understand your question correctly, The answer is no.[:o]
Just take Red's advice and you'll be good to go;)
Pete |
