Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Nitro Engine Fuel
Old 06-12-2011 | 01:35 AM
Default Nitro Engine Fuel
I've got hpi Trophy 3.5 which I use 20% nitro fuel in and I have a 5 litre tub of 16% nitro fuel which I cannot use. Is there any way of making the 16% nitro into 20% nitro?
Old 06-12-2011 | 03:39 AM
Default RE: Nitro Engine Fuel
yes, but why cant you run the 16%?
Old 06-12-2011 | 04:53 AM
you can run 16% no problem witha hot glow plug.
Old 06-12-2011 | 07:08 AM
downunder's Avatar
Just use the 16% fuel and I doubt you'll notice any difference. I've run a car engine on zero nitro and it worked a charm .
Old 06-12-2011 | 01:44 PM
You can run 16% you may have to lean it 1/16 out for the same exact performance as 20.I was told by the owner of my lhs is the higher the nitro content,is just crazy.They are all the same you're just paying more and wearing the engine fast+ there's always that chance of breaking it unless you use extra shims in the head.When you can get the same performance for less money by simply ajusting the high end.I belive it to a point but i just use 20% also Odonnell speed blend.But i wouldn't hesitate to run 16 through it,wouldn't hurt it that's for sure.More lubricant.
Old 06-13-2011 | 05:21 AM
proanti1's Avatar
ORIGINAL: nitroholic
No, you aren't wearing the engine out any faster. Unless you are running too lean, the nitro content will have no effect on the engine internals. If you have an engine that is designed for it, a higher nitro content fuel will give you more a bit power without you having to lean anything out.
Old 06-19-2011 | 11:16 AM
1QwkSport2.5r's Avatar
I've ran as low as 5% in a SH .28 - the only appreciable difference between 5% and 20% is it wouldn't wheelie on 5%. To match the performance of 20% using 5% nitro the head button and squish band need to be machined down a tad to raise compression higher than removing the head shim alone. (I removed the head shim and used a MC59 plug and it ran okay.)
Most sport engines will run on just about any nitro amount, and like proanti1 said; Your engine wear will be no different on any fuel so long as the needles are adjusted properly.
