Heat cycling
#51
RE: Heat cycling
ORIGINAL: eemilioc
I have been trying to find the Hudy prop and cant, do you know where they sell it. It has me thinking how does this prop accepts any size engine, the design must be the key for it.
There is a link earlier in the thread to the prop, drive collar, and prop nut.
#52
RE: Heat cycling
1QwkSport2.5r
The hudy prop has a very high pitch and has some irregular cuts that I imagine are for creating turbulence and increasing the resistance. The other setup that was mentioned before had a simple prop cut on both ends, so there is where I think the resistance is equal in any motor, while the hudy may vary its resistance due to this additional cuts. This is just what I have thought by guessing and looking at the pics.
I have searched for this prop and they dont sell it anywhere, if someone had it and gave us some dimensions and photos would be great to calculate the pitch and fabricate something close to the original.
#53
RE: Heat cycling
ORIGINAL: 1QwkSport2.5r
Purenitro33 - how come the prop is bolted directly to the engine in the pictures in the links provided above? Doesn't look like a gear drive to me. The prop nut especially made for a short car engine crank...
But I'm no engineer, or chemist, or any other sort of smart guy. I just call it as I see it.
#54
RE: Heat cycling
ORIGINAL: purenitro33
I wasn't referring to the other links, only the link that was in my reply. You should never set an off-road engine to operating rpm for break-in, the heat generated from the friction and the load put on the moving parts would damage the engine in short order.
Not rocket science. You guys make it sound more complicated than it is. But don't worry... I won't hold it against ya'll... . I'll agree to disagree again.
#55
RE: Heat cycling
Your theory may be relative and doable with rtr engines that have butter soft pistons and cheap chrome. But try that with a high end engine and you will find it simply doesn't work like that, the heat cause by friction will send the temps skyrocketing at operating rpm, and adding more fuel to the equation doesn't solve that.
You can disagree all you want, but your arguing with people who make a living building and selling these engines. If break-in was just that easy, my life would be so much more simple.
#56
RE: Heat cycling
I have broke in many ABC engines with hard chrome brass liners and high silicon content aluminum pistons. All run rich and never any problems. I have only run them hot enough to stay running. I have a traxxas 2.5R engine that has 15 plus gallons on it and it has the original OEM rod in it as well as original piston and liner. It only takes a few degrees above ambient temp to obtain safe running clearances between the piston and liner. This particular has a real squeaky pinch when it was new too and the rod never broke. Nor did the bushing wallow out on the crank pin end. Save heat cycling for the Meehanite piston engines, that is where the process began and got slurred over to the ABC engines. A high silicon content piston has a very low expansion rate and doesn't retain any growth once heated like meehanite does.
#57
RE: Heat cycling
what exactly is the debate here ? I don't even understand what you guys are disagreeing about ? I Would consider myself quite experienced breaking in ground engines...I have successfully broken in several thousand race engines over the last few years..so not sure what the debate is....
#58
MI
RE: Heat cycling
ORIGINAL: supertib
You cannot breakin a offroad engine at operating RPM's, you will tear up the piston and do substantial damage.......I breakin at 14-16 000 RPM
the prop on a breakin bench may look small, but it provides more load then you will get wth the engine on the ground in the RC car.......... A strong 28 engine will only spin the Hudy prop to 25 000 RPM under max power and tune........It does a hell of alot more then just pass air over the engine....
#59
RE: Heat cycling
ORIGINAL: supertib
#60
RE: Heat cycling
ORIGINAL: JohnP2
Hey, what do you guys think of the O.S. 21XR-B? I've never seen an engine marketed to be easily upgraded. Wouldn't it be more cost-effective just to order the one you want instead of investing in upgrade parts?
#61
RE: Heat cycling
ORIGINAL: Anthoop
Plenty of low rent engines can be upgraded with parts from other engines already....I guess they are only saying it to try and increase sales....sales patter.
ORIGINAL: JohnP2
#62
MI
RE: Heat cycling
ORIGINAL: JohnP2
Understood. I'm curious, however, if it is cost effective. Example: would one spend more getting an O.S. 21XR-B and buying parts to ''turn it into'' a 21X-B V-Spec (or something compatible)....as oppossed with just buying the 21X-B V-Spec. Thanks
ORIGINAL: Anthoop
ORIGINAL: JohnP2
