changing the engine pressure.
From: LisbellawCo.Fermanagh Northern ireland UK, UNITED KINGDOM
hi, the other day when i rebuilt my engine jus to see how it works i noticed that there was a washer/shim between the engine head and the crankcase and i figured that if i were to take the shim out the pressure would increase and therefore the power of the engine would increase but would this damage the engine?
If the shims you are talking about are between the head and the liner, they are there to set the compression ratio to suit different types of fuel. My Picco 26 has 3 shims and is designed to run on 25% nitro. If I were to drop to 10% nitro then I would remove 1 0.1mm shim and if I were to go up to 30% nitro then I would fit an extra 0.1mm shim. The amount of shimming and thickness is part of the engine design but the basic rule is "More nitro, more shims. Less nitro, less shims"
Hope this helps.
Hope this helps.
