Throttle Boot - I need a quick answer please:
My Feedback: (8)
MI
If the throttle arm slide boot has a tear in it; will it cause an air leak? to clairify what I am talking about look at this to see:
http://www2.towerhobbies.com/cgi-bin...?&I=LXDGA6&P=7
My Feedback: (8)
MI
ok so you are saying it is only to stop dirt from hitting it. I want to know if you are saying this becuase the lable of the product says "dust boot" or are you saying this becuase you have actually ran an engine with a torn or missing boot which did not cause an air leak.
For 3.bux just replace it, or you could get a carb. kit that comes with the boot and seals for a few bucks more. for a temp .fix get some rubber sealer and put it on the tear, and ya I've been down that road, RED
My Feedback: (8)
MI
thanks red, I already bought one, its just on the way with a few other things. I just wanted to know if I could run it now without having problems. but its better to play it safe and just wait the extra couple of days. It has about 4 HUGE tears it it, but is still held together and you cant even tell it has tears unless you stretch it out.
On one of my pullers I run a ducted fan engine with a slider carb (OPS) The carb doesn't have a dust cover (it's not designed to have one, because it would normally be mounted inside the airplane's fuselage) I have to check and clean it after each pull to prevent the carb from binding, but it works just fine.
My Feedback: (8)
MI
no its not on my TRX 2.5 engine its on my Force .25, the tears are from accidental poking when trying to adjust the carb very quickly without looking - careless mistake. I just have shown you the 2.5 boot because that was the first thing that showed up when I searched for boot. well micropuller, that is very convincing, if it doesnt have one it should be the same way on my engine - not actually sealing the slide but just stopping the dust (which could cause sticking as you mentioned already)
My Feedback: (8)
MI
I have had my T-Maxx 2.5 for about two years now and it has been loads of fun. My buggy with the Force .25 engine is more racy and a lot faster, but the T-Maxx is much, much more fun for jumping and doing stunts.
oh and thanks for the help both of you: Micropuller and redheat8
