Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Slide Carb Return Spring?
Old 01-15-2005 | 11:21 PM
Default Slide Carb Return Spring?
What is th proper way to put a throttle return spring on a slide carb (in a T Maxx). I found these, but I'm not sure how they work.
http://www.neweramodels.com/item.cgi...hjfomrokpumodv
Right now I have a spring from the front bulhead to the servo arm. I think ideal would be to have it on the carb. The newera spring looks simple and cheap, but I'd like to build something myself. Any Ideas?
Old 01-21-2005 | 09:15 PM
Banned
Default RE: Slide Carb Return Spring?
I don't know the t-maxx, But on my LST it goes right on the carb, The point of the spring is to close the carb if you loose signal, you can use a strong elastic to. Hope that helps, A little
