Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
New engine trouble
Old 05-24-2005 | 06:31 PM
Default New engine trouble
I just baught a os rg .21 motor, and when i recieved it today it was really tight with good compression. The problem is that it seams to have a clank when the piston hits the top of its cycle. Is this normal for a new engine? there is no oil or gas that hs been in it yet, so could it be there is just friction right now or do i have a junk motor?
Old 05-25-2005 | 12:24 AM
Default RE: New engine trouble
Thats normal. They are tight when new which is a good thing.
Old 05-25-2005 | 11:46 AM
so your saying when it hits top it should clank. i have a sirio .27 that is brand new and very tight, but doesnt clank.
Old 05-25-2005 | 06:49 PM
SManMTB's Avatar
If you mean the play you feel when piston is at TDC then that's normal. If you open up the back plate and look at the rod and crank when the piston is at TDC you can turn the crank slightly without the piston movin.
Completely normal. It feels slightly different on different engines.
