when you tune what you tune first? REPOST
RE: when you tune what you tune first? REPOST
ORIGINAL: snowbl!nd
Usually an erratic idle is the result of a lean low-end, but if you've tried richening it and it hasn't made any difference i'd suggest an air leak.
Yeah, I had a similar problem like that before and it took me a long time to work out that I had a screw come off the carburetor mounting. Make sure there all there.
I've got a brand new TNX that has been broken in and I don't know what the hell LSN and HSN means. The bottom needle is on factory setting is at factory setting (one turn). The smaller screw I haven't touched yet but the top needle that adjust the mixture is half a turn in from factory setting. Any suggestion in plain english pleeese.
AZ
Plain English:
L ow
S peed
N eedle
H igh
S peed
N eedle.
The bottom needle? Your LSN?
The smaller screw just might be your idle screw. But it's usually lower than both your LSN and HSN.
L ow
S peed
N eedle
H igh
S peed
N eedle.
Thanx for the explanation! So the LSN controls the power from idle to mid throttle and the HSN is when it goes past mid throttle? So if I want stronger pull-away, do I srew the LSN in or out? And for higher straightline speed I adjust the HSN in?
