Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Need New Engine for HPI
Old 04-03-2006 | 07:39 PM
Default Need New Engine for HPI
I have a Nitro RS4 3 EVO with a T-15 Engine. What would any of you recommend to put on my car to go way faster? O.S., Novarossi, HPI, etc.? I might also need an engine mount.[8D]
Old 04-03-2006 | 07:59 PM
laserman2's Avatar
Default RE: Need New Engine for HPI
OS 18 should be a direct drop in
Old 04-03-2006 | 09:01 PM
OS .30 ..........some mods needed
Old 04-04-2006 | 08:55 PM
ORIGINAL: laserman2
Which OS 18? TZ or CV-R?
Old 04-04-2006 | 09:00 PM
laserman2's Avatar
the cv-rx should be
Old 04-05-2006 | 09:55 PM
I was thinking about getting an 18 TZ. Wouldn't it work also? Here's a review:
(Requires ADOBE READER)
[link=http://www.osengines.com/reviews/osmz2110-dynotest-rcnitro.pdf]http://www.osengines.com/reviews/osmz2110-dynotest-rcnitro.pdf[/link]
Old 04-06-2006 | 11:22 PM
What ever you pick i hope you know that the engine unless it has significantly more rpm then your last engine did your car's on the top end speed will not any faster then what it is now. It will accelerate a lot faster but your overall speed will pretty much stay the same. If you want more top end speed you will have to change the bell gear or the spur gear for that.
With that being said i would go for the O.S .18 cvr i have this engine and it has a ton of power and is very easy to tune. I used the heat cycle method on my engine to break it in and it runs better then i could have ever hoped for.
Old 04-07-2006 | 03:33 AM
Whatever engine you choose you cant really go wrong with OS. I personally reccomend a CV-RX due to the pull start.
