flywheel problem
CA
hey
do you need to use a certain tool in order to remove a flywheel? cause im trying to take the flywheel off my os rg and it won't budge .
i don't want to force it and damage it because im going to sell it
anyone have any tips on how to remove a flywheel if you don't have that tool (if there is one)?
thanks,
pat
thanks,
pat
Or carefully use a soft blow hammer set the end of the crank on a block of wood and gently tap it off. The only trouble with pullers is that they can bend the flywheel!
