suggestions??
suggestions??
I've went through two pullstarters recently. does anyone know of a good pullstarter for the 4.1 savage x engine. i have the roto start to fall back on but would like to find a pullstarter with metal insides cause that's where they keep breaking. maybe the next one i get i'll take apart right away and put different line in it so it won't get to the end and cut into the inside spool. any other suggestions would be appreciated! Thanks
RE: suggestions??
you don't have to act like an a** i was looking to see if anyone had found a better pullstarter. i'm coming to the conclusion that it's hydrolocking causing the problems!!! thanx
ORIGINAL: hpi apollo
stop pulling the thing so freaking hard and out so far and dont hydrolock the engine, simple
RE: suggestions??
i wasnt meaning it in an offensive way (if i came out like that which im sure it did) plus i was tired, my bad
the general rule is if it doesnt start with 8 inch pulls then you are doing something wrong
