Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Which Engine to get???
Old 05-05-2007 | 04:56 PM
Default Which Engine to get???
Hi guys .i have had my savage x for 2 seasons now,first season was horrible with alot of broken parts and at the end of the season,my engine the f4.1 blew the crank.Started this season 2 weeks with a new motor from the box,broke it in the right away and today i think the engine blew again.I got a axial .28 for my new pro r i heard the motor is pretty good the price.what u guys think i should get for the savage that will last 8 gallons.these hpi motors are really junk only 1 gallon thru it im using 20% nitro 12% oil.thanks any input welcomed.
Old 05-05-2007 | 05:18 PM
Default RE: Which Engine to get???
yea i really hated HPI motors, axials are good but dont have much power, same power as the hpi 4.6 basically....another good cheap engine is the STS .30, i heard that hauls ***** in savages. If you want the most reliable engine not too expensive, would be a picco .28 in my book, those 2 engines are the best in savages in my opinion. very very sick mills.
Old 05-05-2007 | 08:05 PM
SAVAGEJIM's Avatar
For the Savage, yes the STS D30M is a very good engine for the cost. It will spank the F4.1 and K4.6 and Axials easily. A very powerful engine with alot of race features at a very chap price.
Old 05-05-2007 | 09:32 PM
Codeblack's Avatar
lol, well said
Old 05-05-2007 | 11:14 PM
thanks guys i will decide later.any other inputs welcomed
Old 05-06-2007 | 12:05 AM
Codeblack's Avatar
Here's some you can look into
#1) Novarossi 528 modded
#2) RB 928/728
#2) LRP spec-3 / Z.28R 8 ports
#3) SH .28 Prospec 8 ports
#4) .30 STS RB modded
#5) .28 Jammin
#6) .28 OS
Old 05-06-2007 | 12:06 AM
Codeblack's Avatar
you cant go wrong with any of these: http://www.amainhobbies.com/index.php/cPath/1_23_79
Old 05-06-2007 | 10:50 AM
cool,i will decide on STS .28 stock not the mod.what u guys think.any objections.send me any links to where to buy this engine thanks.
Old 05-06-2007 | 10:58 AM
the .28 has a thinner sleeve and will lose comression faster then the .30, i would go sts .30...
Old 05-06-2007 | 11:35 AM
Codeblack's Avatar
also .28 has 3 ports instead of 5 thats .30 has. So if you wana go sts, i also suggest you go .30 its a little more top end
Old 05-06-2007 | 05:48 PM
thanks for that info maybe i will go with a sts .30 then,any other input is good
Old 05-10-2007 | 10:43 AM
ORIGINAL: paulino966
No other input needed STS D30M all the way. Have one in my Revo and its an absolute
animal, and is easy on fuel for an engine of this displacement. One thing it takes at least a
gallon of easy running before you can race tune the carb and run sustained full throttle
blasts. You will need to pull the head shims used for break in from the factory after the
one gallon break in period. With this engine run one silver shim for 30% and either one silver
or copper with 25%. This engine is designed for 30% and the matching STS tuned pipe
because of its agressive port timing.
If you are not smelling nitro fumes and listening to the sweet song your not LIVING !!
