Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Risks
Old 06-16-2007 | 02:11 PM
Default Risks
What are the risks and problems that starting a pullstart engine on a starter box will cause? (the pull start is still one the engine)
Old 06-16-2007 | 08:56 PM
GRANT ED's Avatar
Default RE: Risks
No risk and no problems. It will work just fine.
Old 06-17-2007 | 12:30 AM
SAVAGEJIM's Avatar
Default RE: Risks
The only problem I can see is if the vehicle is not designed to use a box starter. For example, the Savage truck cannot be started with a box; it must be started with a pull start or roto start.
In addition, the Traxxas 4-tec (at least the older one with the TRX2.5) cannot be started with a starter box because the flywheel is too small. A larger flywheel would be needed in this case so the starter box wheel will hit it.
Old 06-17-2007 | 02:43 AM
GRANT ED's Avatar
Default RE: Risks
I guess it depends on what car you have as to if it is physically possible to use a starter box but as far as damaging your engine is concerned it is not a problem. I have a PS buggy that I always start with a starter box and have had no trouble at all.
