TRX 2.5 issue. PLEASE HELP!!!
ok i got a trx 2.5 in my nitro rustler and it works just fine with the stock pipe at cold or hot temp, but when i put a new chrome TSAIS tuned pipe the only thing that changes is the low end and then after the engine heats up to normal temp it seems to like stall or something when i let off the throttle. and during take off its slower than when it was cold...[:@] what could the problem be? i noticed the backpressure was more when i blew thru the stock pipe and on the new pipe air moves more freely? would not enough back pressure cause this? please help, and thank you for all the help in advance!!
ORIGINAL: All4_Nitro
MD
i think yes, i went back to my stock pipe on my jato 3.3 for the same reasons. when i did all problems went away. see if you can get a resinator pipe that should help
yea i kno right. im almost ready to do that, but one prob. i already sold it on ebay!!! yikes!!! well maybe i can fix it somehow. i hope!!!
umm have you tried re-tuning? tuning needles compensates for different small changes that have been done
I think nearly every pipe requires a retune when you first install it
