Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Problems running in os 18tm.
Old 08-07-2007 | 06:49 PM
Default Problems running in os 18tm.
Ive just installed a os 18tm into my revo and went out to break the engine in. I fitted the flywheel, clutch shoes and clutch bell on correctly as per traxxas exploded diagrams but when i start the engine to run it in the crankshaft and flywheel spin but the clutch bell isn't and the truck doesn't move at all. Ive idled thru the first tank of fuel.
Can anyone help me?
Old 08-07-2007 | 07:21 PM
Default RE: Problems running in os 18tm.
sounds like you installed the clutch shoes in the opposite direction that they are supposed to be,it happens especially when your all exited about a new engine
Old 08-07-2007 | 07:30 PM
wot so flip em round? they look the same both sides.
cheerz dude, i'll give it a try
Old 08-07-2007 | 08:04 PM
well ive turned the clutch shoes round and will see wot happens in the morning!
fingerz crossed
Old 08-07-2007 | 08:47 PM
yes both sides look the same ,but when you intsall the shoes on the pins,turn the flywheel so the pins are horizontal,when you putt left shoe on it should point up,right shoe pointing down.if you have them the opposite way they wont engage the clutch bell
Old 08-08-2007 | 10:08 AM
well i flipped the shoes round and it moved for a few mins then stopped again and just revved. i have now used 2.5 tanks to run it in so have another 2.5 left will it wake up when the break in period is finished?
thanks
Old 08-08-2007 | 05:58 PM
oh yes it will wake up,it comes from the factory with really rich settings on the needles,remember you may have to lean it out an 1/8 turn on the hsn,and maybe a 1/16 on lsn after every tank as the engine wears in.if its back to revving again check the flywheel nut,it would not be the first one to ever come loose,especially if you didnt use some lock tite,
Old 08-08-2007 | 07:34 PM
tried to carry on with the break in earlier but the throttle servo has now decided to stop working so will have to get one of those tommorow. will run another few break in tanks off and let u know if she wakes up (lazy git) lol
cheerz megamaxx
