what engine can replace the 15cxp
QC, CANADA
i i have an smartech winner pro with the stock 15 cxp engine that it a *** to tune and that always has to be tuned
I would like to know with what engine can i replaced it and waht parts of the should i have to chnage by swaping another engine ??? and if someone has already swaped another engine in smt winner pro ??
thank U guys
thank U guys
just about ANY .12 .15 .18 will bolt on
if your racing maybe try JLR.12 red-dot picco on-road,O.S. 12TZ Spec II,novarossi,sirio,or RB
QC, CANADA
But do i have to chnage some parts like ( clutch , flywheel, engine mounts etc ) or brands have some kind of standard for that ???
Just make sure whichever engine you buy has a threaded crank and rotary carb. Then you pop off the flywheel/clutch assembly and slap it on the new engine. Then, 4 bolts and you're done, time for break-in.
QC, CANADA
ok nice thank u ! is an O.S. .18 "bolt on" with the flywheel clutch etc ???? ans is it an overall good engine ??? any suggestion ?
