Weston 5.8 (Webra .36 )
My Feedback: (8)
I hope this link works [8D]
http://www.westonuk.co.uk/index_018.htm
Edit: Ahhh...I see it does
In case some of you don't know, Webra makes some of the highest quality engines around...and if they run anything like their airplane and heli engines (and I'm pretty sure they will ) they should kick serious butt...
RE: Weston 5.8 (Webra .36 )
WOW, I thought they were gone. Back in the late 80's I used a Webra .40 in a pilon racer (plane). It was far faster than anything OS or the others had to offer at that time and it lasted along time. Very high quality stuff.
wow i found in this site that a magnum 21 is the same with gx-21 kyosho! if you look closely you will se the same pullstarter,carb,backplate,case only difference the rear exhaust port which is round in the magnum!
http://www.westonuk.co.uk/index_011.htm
