turbo plugs
RE: turbo plugs
No. The turbo plugs seal the gap with a tapered edge, but the standard plugs seal it with a washer. You wouldn't even be able to get a standard plug into the button.
MI
RE: turbo plugs
Actually the turbo plugs are larger than standard plugs. That and the threads are different. The standard plug will just fall into the hole where you would use the turbo plug. You can't even use a turbo plug in place of a standard plug cuz it's just too big.
