Question on Air Filter Oil
Hi, Im into off-road buggies and truggies. Can anyone tell me if I can use something like thick gear oil (e.g. HD SAE90wt) to subsitute as air filter oil? What so special about RC air filter oil anyway?
Thanks for your replies.
RE: Question on Air Filter Oil
ORIGINAL: SManMTB
Why try to save a few $$$ when a failure will cost you hundreds. Seriously, get some real air filter oil.
Where I stay there are 3-4 hobby shops and they always run out. I just have one bottle of mugen air filter oil left. Over here they do not have the marvel mystery oil. So you can say I am in a bind. I know I am risking the life of my engine; but I do need a substitute for my air filter oil.
CT
the oil''s there to trap fine dust particles. if you''re not running in extremely dusty areas you should be alright with motor oil. gear oil i''m sure is way too heavy. just clean the air filter often and it''ll be fine. if its dusty you''ll want to clean the air filter often anyways because with whatever oil you''re running, all the dust that gets caught in there starts to restrict airflow pretty quickly and effects performance.
Yes, auto trans fluid. After hearing that trans oil is the same as ARO a friend did some chemical test on ARO at his work and it tested almost the same as trans fluid he tested. Iam not saying use it, but i use it and it works fine for me.
I have the same problem as i drive to the LHS for ARO and they are out. I do shop online alot more now as sick of the 2 local LHS not having stock of basic items.
go to the closest dirt bike shop and buy foam filter oil. one can will last you a year and work better for the same price as a bottle from the hobby shop.
