OS Speed
IL
OS Speed
Are your guys OS Speeds holding up in the crankpin/con rod area were the original V-Specs failed quickly? Mine has slop in it and I was wondering if it would be worth my while to put a speed rod/crank in my original V-Spec since my piston and everything is good to go. Will it fit?
I just dont want it to wear out again and have all this wasted money. I know the Speed cranks are hardened or hard coated for long lasting.
FL
RE: OS Speed
I have no play on mine or my friends. Make sure your not high speed killing your crank pin. If you short gear your car and hold it at top RPM too long, it will wear out the crank pin early.
