My Crank shaft broken !!! HELP PLEASE
Friends ... My crank shaft is broken ... Likely for the use or wear.
Searching the Internet I not found the parts, on ebay but found .28
This crank shaft of the force .28 will be served?
Please if you know of any page where you can buy the parts were very much ..
Greetings!
Greetings!
RE: My Crank shaft broken !!! HELP PLEASE
Do some research, find out which Force .28ci engine it is. Then, look on the net for on-line stores that sell Force engines and Force engine replacement parts.
Personally, I would simply thow it away, it will be more economican to buy a new engine thatn trying to rebuild this one. Once you replace the crank, chances are (if it is worn like you say) that the piston & slever are shot also. Additionally, the internal engine bearings might have been damaged from the crank being boken (I do not know just how it was broken, but the shock of the con-rod shearing the crank pin off from what ever destroyed it could have stressed the bearings and other stuff on the inside of th block.).
