Picco P3 Turbo head to shim or not to shim?
Hey guy's I'm thinking about going turbo head with my P3, and need to know do you run the standard three shims or do you make a change? Also is this the [link=http://www.amainhobbies.com/product_info.php/cPath/1_68_164/products_id/8922]TURBO HEAD [/link] I need. Finally what turbo plug is recommened?
TIA
TIA
FL
RE: Picco P3 Turbo head to shim or not to shim?
I would call Ofna directly, I could only find a couple of parts for the P3 on ofna parts list and a turbo button was not one of them. When I have had any question that no one could answer, Ofna has helped out.
ORIGINAL: supertib
for a P3 28 you want to start with .5 mm of shim...2 thick 1 thin
ORIGINAL: savagedan89
part number 51536
part number 51536
ORIGINAL: NitroTherapist
Shims modify ignition timing right??
