Nitro %'s
#51
AB, CANADA
RE: Nitro %'s
I will be a "guinnea pig here" I have been using 5% model airplane fuel in my R/C cars since the /70's with long lasting engine results, as well as good running and tunability. I am currently running a T-Max with the original 2.5 rear exhaust. I was using Omega 5% for the castor oil content. I started having "varnishing " problems as would be expected with the castor. I now blend 500ML of Omega 5% with 500ML Cool power 5%, the results are excellent and cooler, cleaner running. engine still has good pinch. I will keep you posted on the engine life as I progress.
#52
RE: Nitro %'s
ORIGINAL: kersplat
I will be running Omega 5% when I'm done with my Sidewinder 30% and Coolpower 15%
How does the Omega 5% compare to running it on a Car fuel with 20% or 30% nitro? The sidewinder I'm using has 12% oil so how would that compare to using 17% with 5% nitro?
A video would be great too.
#53
AB, CANADA
RE: Nitro %'s
JB COMP,
I don't really see much difference between High nitro "car" fuel and 5% "Aircraft" fuel. The T-Max has retained the snappy quick throttle response when I compared to a tank of O'Donnel's and a tank of the Morgan's "Omega /Cruel power" 50/50 blend. With my blending of the two fuels, I noticed even the "Traxxas"plug seems to be cleaner. I mainly "backyard Bash" in a local football field, so I have many 40 MPH 100Yd runs in second gear. Speed is fun . So far the upper end of the original con rod hole is still not "egged out". It must be the castor . All I know so far is the piston skirt is not tightened up with a heavy coat of varnish, just a light tan . Afterall if the piston gets too thick a coat of Varnish, it will not run cool. Mabe I will put one of my ole Veco 19 (McCoy piston/Ring), in the T-Max. Do you think it would still have the guts to make the Max sing?
#55
RE: Nitro %'s
Sidewinder has alot of castor and suppose to be full castor so changing to a 30/70 should be a little better. BTW I can get a gallon of coolpower/omega for $10.00 what can you guys get it for?
#56
AB, CANADA
RE: Nitro %'s
My Veco .19 is a car engine. This is what we used in the /70's . When modified with Dick McCoy hop up heads , cranks and piston/sleeve combos, these engines were just short of the newer K&B 3.5 cc in HP. I can get Cool Power and Omega for $14.00 Canadian here.
#57
RE: Nitro %'s
ORIGINAL: kersplat
#58
MA
RE: Nitro %'s
how the hell are you people getting a gallon of nitro for 14$?
I can barely get a quart of 20% for 14$...
Is this blending your own fuels only for planes? Us people with nitro cars can't get a gallon for 14$...
#59
RE: Nitro %'s
ORIGINAL: rpg711
I live in Navarre FL (which in the USA) Morgan fuels is just a little under 2 hours away and one of the local shops drives there and gets the fuel right from the factory so he doesn't pay shipping on the fuel and that means neither do I.
#61
GA
RE: Nitro %'s
its cheaper to buy by the gallon. its even cheaper to buy by the case.
if at all possible, by fuel from local shops. shipping is a killer when it comes to fuel. i think tower charges like $40 to ship a case of fuel
#62
RE: Nitro %'s
ORIGINAL: youwish16
I figured I can get a case of Omega 5% for $42.60 out the door. Where I'm paying $26 something out the door at another LHS for a gallon of Sidewinder Race 30%
#63
PA
RE: Nitro %'s
ORIGINAL: wjvail
running 50% nitro in an engine that has be optimized for 25%, without modification, is asking for trouble.
but anyways... what kind of modification are you talking about? just adding head shims? or will some work on things like engine timing yield better results with higher nitro?
i'm pretty well versed in 4-stroke 1:1 theory (i've got a supercharged mustang i drag race), and i know that more oxygen=more cylinder pressure=more power. isn't it that simple in smaller scale 2-strokes?
