Second Time ... broke crankshaft engine Ofna .32!!!
Not that's what happens ...
some time ago was broke the crankshaft engine of my .32 Ofna 9.5 .... buy a new crankshaft and what place the engine ... after 4 runs again broke on the same side ... Attach photos to think about this problem.
view pics.
view pics.
RE: Second Time ... broke crankshaft engine Ofna .32!!!
ORIGINAL: feguez
what engine run you? best?
ORIGINAL: JB COMP
That's why I don't run Force engines.
ORIGINAL: Hordsak
Best run engine I, LRP .28! fast go
ORIGINAL: feguez
ORIGINAL: JB COMP
It would not be the best engine Axial .32 Spec 1S Engine Gray
have more ports the cilynder... !!!
ORIGINAL: feguez
ORIGINAL: JB COMP
I run a Mach 427 in my CRT which is one of the heavier truggies out there and it trows it around just fine, or you can get the Sportwerks 26 V2 which is the same as the Mach 427 just with a different carb. you can get the Mach 427/SW26 for $130 - $150 on Ebay.
Or the STS 28 5-port I heard was good or the new S28 if its anything like the S21T I heard good things about. (these are not pull start engine so I'm not sure if you could use them)
The Axial 28 Spec 1 I heard was a good MT engine for cheap you can get one at Amainhobbies.com for $109.99
In a 9.5 buggy you want something with some top end since it does take much torque in a buggy, I have a LX Comp which has some of the same parts as the 9.5 I run a STS 21B in it and it does well.
With a 28-32 engine in a buggy you want to gear it up since a 28-32 will lack the top end a good 21 will have.
NV
I have a 32 force crank and block here Id send you for the cost of shipping, If you don't need the pull start option I will pin and weld the crank so it wont break any more. Send a PM of your interested.
